Snippet Needed For 74HC165 Three Pin Hookup
idbruce
Hello Everyone
I am searching for a 74HC165 snippet for a three IO pin hookup. The OBEX has an object, but it utilizes four pins. Any input would be appreciated.
Bruce
Bruce
http://nutsvolts.texterity.com/nutsvolts/201005/?pg=17#pg17
EDITED: Here is a much better link to the solution
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp6.pdf
While reading the input from this shift register, I will be shifting 8 bits into a global variable, during which time only 1 of the 8 available inputs will be valid.
Can I test for valid input with the following conditions?
IF Shift_Register_Output == 128 'Binary pattern %10000000 (Button 1 pressed) Function1 ELSEIF Shift_Register_Output == 64 'Binary pattern %01000000 (Button 2 pressed) Function2 ELSEIF Shift_Register_Output == 32 'Binary pattern %00100000 (Button 3 pressed) Function3 ELSEIF Shift_Register_Output == 16 'Binary pattern %00010000 (Button 4 pressed) Function4 ELSEIF Shift_Register_Output == 8 'Binary pattern %00001000 (Button 5 pressed) Function5 ELSEIF Shift_Register_Output == 4 'Binary pattern %00000100 (Button 6 pressed) Function6 ELSEIF Shift_Register_Output == 2 'Binary pattern %00000010 (Button 7 pressed) Function7 ELSEIF Shift_Register_Output == 1 'Binary pattern %00000001 (Button 8 pressed) Function8CON Input = 0 , Output = 1, Low = 0, High = 1, Off = 0, On = 1 , NoEnablePin = -1 PUB Out ( OutputLatchPin, OutputDataPin, OutputClockPin, OutputEnablePin, OutputBits, OutputByteValue ) DIRA [OutputLatchPin] := Output 'SET the LATCH Pin to OUTPUT OUTA [OutputLatchPin] := Low 'TOGGLE the LATCH Pin OFF DIRA [OutputDataPin] := Output 'SET the DATA Pin to OUTPUT OUTA [OutputDataPin] := Low 'TOGGLE the DATA Pin OFF DIRA [OutputClockPin] := Output 'SET the CLOCK Pin to OUTPUT OUTA [OutputClockPin] := Low 'TOGGLE the CLOCK Pin OFF REPEAT OutputBits 'Start REPEAT LOOP for vNoOfBits ie 8 OUTA [OutputDataPin] := OutputByteValue >> (OutputBits-1)'SET the DATA pin to the first bit OutputByteValue := OutputByteValue << 1 'SHIFT the BYTEVALUE to the Next Bit OUTA [OutputClockPin] := High 'TOGGLE the CLOCK Pin ON OUTA [OutputClockPin] := Low 'TOGGLE the CLOCK Pin OFF WAITCNT(1_000 + CNT) 'WAIT for some time and REPEAT OUTA [OutputLatchPin] := High 'TOGGLE the LATCH Pin On WAITCNT(1_000 + CNT) OUTA [OutputLatchPin] := Low IF OutputEnablePin <> NoEnablePin '-1 = Dont use the ENABLE Pin, > -1 = Use the enbale Pin DIRA [OutputEnablePin] := Output 'SET the ENABLE Pin to OUTPUT OUTA [OutputEnablePin] := Low 'SET the ENABLE Pin OFF, THIS STAYS OFF FOREVER! PUB In ( InputLoadPin, InputDataPin, InputClockPin, InputBits ) : InputByteValue | InputInBit InputByteValue:=0 DIRA [InputLoadPin] := Output 'SET the LOAD Pin to OUTPUT OUTA [InputLoadPin] := Low 'TOGGLE the LOAD Pin OFF WAITCNT(1000 + CNT) 'Wait for some time OUTA [InputLoadPin] := High 'TOGGLE the LOAD Pin ON DIRA [InputDataPin] := Input 'Set DATA Pin to INPUT DIRA [InputClockPin] := Output 'SET the CLOCK Pin to OUTPUT OUTA [InputClockPin] := Low 'TOGGLE the CLOCK Pin OFF REPEAT InputBits 'Start REPEAT LOOP for vNoOfBits ie 8 InputInBit := INA[InputDataPin] 'READ the DATA pin (bit value 1 or 0) InputByteValue := (InputByteValue << 1) + InputInBit'SHIFT Left and Add to the BYTEVALUE the Next Bit OUTA [InputClockPin] := High 'TOGGLE the CLOCK Pin ON OUTA [InputClockPin] := Low 'TOGGLE the CLOCK Pin OFF WAITCNT(1000 + CNT) 'WAIT for some time and REPEATto use ( for getting a button pressed)
vButtonPressed := Shift.In(InputLoadPin, InputDataPin, InputClockPin, InputBits)
Use the case statement for checking against the button values INSTEAD of the multiple if statements
regards
Dave M
case Shift_Register_Output 128 : Function1 64 : Function2 32 : Function3 16 : Function4 8 : Function5 4 : Function6 2 : Function7 1 : Function8Was my assumption was correct, that I could take those bits (as a byte) and compare it to the decimal values stated? I am assuming that I can, because your reply contains the same values.
Bruce
128 == $80 == %1000_0000
The Propeller IDE doesn't care which format you use. For binary inputs like you're using, I tend to use binary formatting. Had I written the code I would have done this:
case Shift_Register_Output %1000_0000 : Function1 %0100_0000 : Function2 %0010_0000 : Function3 %0001_0000 : Function4 %0000_1000 : Function5 %0000_0100 : Function6 %0000_0010 : Function7 %0000_0001 : Function8My original point is that case is easier to follow (and probably generates the same amount of code).
I definitely appreciate it.
Bruce
I missed half of that when I first read it. That is definitely a whole neater than a bunch of IF's, and I guess a binary comparison makes a lot more sense also. Thanks again Jon.
Bruce
CON Button1 := %1000_0000 Button2 := %0100_0000 Button3 := %0010_0000 Button4 := %0001_0000 Button5 := %0000_1000 Button6 := %0000_0100 Button7 := %0000_0010 Button8 := %0000_0001 then to use them PUB Main ButtonPressed := Shift.In (InputLoadPin, InputDataPin, InputClockPin, InputBits) CASE ButtonPressed Button1 : Function1 Button2 : Function2 Button3 : Function3 Button4 : Function4 Button5 : Function5 Button6 : Function6 Button7 : Function7 Button8 : Function8PS Did you use my Shift register code? It uses 3 pins ( as you were asking for)
regards
Dave M
I really like your constant idea for the buttons, I will use that idea. As for the shift register, I used Jon's code, because your code was using an extra variable for the individual bits. Additionally, it looks as though your 595 code uses four pins. For a 595, here is what I use:
PUB RetractSpringRemover(nSteps, nStepDelay) Coil_Index := 4 repeat nSteps Coil_Index++ if Coil_Index > 7 Coil_Index := 4 HC595_Data_Block := Coil_Array[Coil_Index] ' Write 8 bits of data. Data byte is output MSB first. repeat 8 'shift out 8 bits outa[Serial_Data] := HC595_Data_Block 'shift out next bit outa[Clock] ~ 'clock low then high then to cycle the bit out outa[Clock] ~~ waitcnt(nStepDelay + cnt) HC595_Data_Block >>= 1 'shift next bit outa[Latch]~ 'cycle low-high-low to cycle the latch outa[Latch]~~ 'toggle the Latch pin to latch the output outa[Latch]~ DeenergizeCoilsBut I do appreciate your effort and code. Thank you David.
Bruce
Hi Bruce,
If you use more than 1 shift register you need define the no of bits to get from the device's. It's usually 8bits per chip.
I use many shift registers daisy chained together, and on some of my boards I use multiple sets, So By using the ONE very simple Object, you can refer to ( use) and no of devices, Just put 8 in the place of the variable.
I do encourage you to use more GENERIC CODE, It looks like that code is for a specific purpose. Also I can't see the PIN Definitions for the shift register?
Also, ALWAY use CONSTANTS for ALL your pin definitions and any other hardware, such as buttons. leds, modes etc,It makes coding much more READABLE, RELIABLE & REUSABLE, as you only need to change the value of a constant ONCE, especially if you use that constant in more than one place.
One other thing, regarding constants, Did you notice the use of "Input", "Output", "High" , "Low" etc, I Alway do this for ALL My projects, and all my objects, So that I can easily read these states in my code, much better than 1, 0, ~, ~~ etc
regards
Dave M
I must say that all makes perfect sense. It sounds like you have a good head on your shoulders for programming microcontrollers
Over the last several months, I have been using constants a lot more than in the past, and I imagine that I will continue in that direction. However, I must say that I am also becoming accustomed to seeing and quickly understanding the ~ and ~~. In the past, I used HIGH and LOW, but I found that I save coding time by using the symbols instead.
I definitely need to start incorporating case statements in my code, because it is easier to write and read. Considering I started with no knowledge of Spin when I began this current major programming endeavor, all of my code needs to go through the refining and beautification processes
Anyhow, thanks for your advice David.
Bruce
P.S. Jon keeps telling me the same thing
