SD Card failiers
Have any of you guys had problems with SD Card failures in the field ?
We are using the FSRW Femto drivers and more or less the same circuit
that is on the Parallax Dev boards. We have seen three of the SanDisk 2 GB
cards fail and one of the Kingston cards become readable in the PC but not
in out PoS terminal.
Our circuit is enclosed.
I have about ten SD cards, which I use heavily both in props and with SD/USB adapters, and I haven't had a failure yet. But I got them all from domestic retailers like Office Depot, generally on sale but not as cheap as some of the sketchier online sources.
And, you might want to try adding another 1uF to your bypass as the writing might consume >100+ mA.
tantalum cap very close to the SD card socket on the board. Do you think that is enough ?
It is also the bulk storage for the processor.
I think that someone should do some real but independent testing.
