Basic Stamp not found and overheating
This is my first post but I've been browsing through these forums for my projects. I'm pretty new to microcontrollers but I have been around circuits so I'm not completely unknowledgeable. I have run into a problem with my bs2 module on my USB board of education. I had a circuit consisting of 3 IR sensors that were connected to the servo ports and 2 LED lights connected to P0 and P1 with a 9V AC plug. There were no resistors or anything else in the circuit and it was working find for a while, but when I turned it on today and tried to upload a the program again it said "No basic stamp found" and I noticed that the module is heating up. It seems that the black chips under the "BS2" and "Rev J" seem to be the ones heating up but I can't tell for sure. I have included the code I was running too. I hope the chip isn't fried but I've changed everything.
' {$STAMP BS2}
' {$PBASIC 2.5}
OUTPUT 0
OUTPUT 1
LED CON 0
LED1 CON 1
Initial:
LOW LED
HIGH LED1
PAUSE 1000
GOTO Sensor
Sensor:
DO
DEBUG "Pir2:"
DEBUG BIN IN15, CR, LF
DEBUG "Pir2:"
DEBUG BIN IN12, CR, LF
DEBUG "Pir3:"
DEBUG BIN IN13, CR, LF
PAUSE 100
IF IN15 = 1 THEN Flash
IF IN12 = 1 THEN Flash
IF IN13 = 1 THEN Trip
LOOP
Flash:
HIGH LED
LOW LED1
PAUSE 7000
GOTO Initial
Trip:
LOW LED
PAUSE 100
HIGH LED
PAUSE 100
LOW LED
GOTO Sensor
' {$STAMP BS2}
' {$PBASIC 2.5}
OUTPUT 0
OUTPUT 1
LED CON 0
LED1 CON 1
Initial:
LOW LED
HIGH LED1
PAUSE 1000
GOTO Sensor
Sensor:
DO
DEBUG "Pir2:"
DEBUG "Pir2:"
DEBUG "Pir3:"
PAUSE 100
LOOP
Flash:
HIGH LED
LOW LED1
PAUSE 7000
GOTO Initial
Trip:
LOW LED
PAUSE 100
HIGH LED
PAUSE 100
LOW LED
GOTO Sensor
Neither one causes the Stamp to overheat. I always get worried when someone talks about using a 9V AC plug since the fastest way to destroy a Stamp is to connect it to an AC power source, but you didn't describe how you used the "plug". I suspect your Stamp is damaged. Call Parallax Tech Support tomorrow for assistance.
These are the ones that I suspect may be burned up.
Yes, try running a simple program to see what happens. If it doesn't work just call Parallax Tech Support.
Good luck,
Mark
Really??
Connecting LED directly to Stamp is asking for trouble.
It may work for a while since Stamp limits the output current ( per pin and per all output) , but it would definetly get warm.
Your LED output needs to have a current limiting resistor - depending on the LED requirement - 1KOhm may do.
