64 column VGA text driver in one cog - 48/40/32/30/24/20...rows! (RELEASED)
Bill Henning
For quite a while now I've wanted to make a high resolution VGA text driver for the Propeller.
My initial impetus was trying to free a cog on PropCade - I did not like using two cogs for a text driver!
It took quite a while to figure it out, but I got it working. Now I need other people to test it and send me best timing settings for their monitors, as I will submit this object to OBEX and GOLD OBEX later.
I present:
MikronautsVGA64 - 64 column driver, requires 5MHz crystal for 80MHz prop clock speed
I guess this answers the more chars thread
http://forums.parallax.com/showthread.php?129470-more-chars-with-VGA_Text.spin
(updated) I added VGA_Text like methods, so it should be a drop in replacement (except for palette handling).
I am MIT licensing the driver. Please don't change the file names so at least I get some exposure out of it
The archive contains five fonts, and the number of times each scan line is displayed can be set in the driver, so this one driver provides the following text modes:
64x60, 64x48, 64x40, 64x32, 64x30, 64x24, 64x20, 64x16, 64x15, 64x12, 64x10, 64x8, 64x6, 64x5
It is a regular "text mode" driver, and as such, uses one byte per character in the screen buffer.
The first 128 characters contain 32 graphic elements, then 96 ASCII characters, and the second 128 characters normally contain the inverse of the first 128 characters. The font is interleaved - this was the only way I could get the driver to work fast enough to get 64 columns!
I have two other variations of the driver that I will be posting that also need to be tested:
MikronautsVGA80 - 80 column driver, requires 6.25MHz crystal for 100MHz prop clock speed
MikronautsSVGA50 - 50 column driver, requires 5MHz crystal for 80MHz prop clock speed
Apr.3/2011 Update:
I added kuroneko's sync patch, which fixed the waitvid hub sync issue - the driver seems solid now! I will be fixing the extra pixel problem he found in the 8x8 font tomorrow.
I present:
Apr.3/2011 Update:
I updated the driver in the first post - the new version adds untested port of the VGA_Text methods, however the color changing methods are ignored as my driver can only provide unique foreground/background colors for each scan line.
I also added methods so that parent objects can retrieve the addresses of the screen buffer, color palette and font base.
hf = 12' 'horizontal front porch pixels, scaled by .8
hs = 76' 'horizontal sync pixels, scaled by .8
hb = 40' 'horizontal back porch pixels, scaled by .8
The above values are approximately 0.8x the VESA values for 640x480@60Hz, which is the correct scaling given how I am generating 64 columns at 80MHz.
I've found it best to adjust the values in 4 dot clock periods, and do not reduce hb below 32 or the waitvid's won't be synced properly
repeat repeat 10000 vga.scrollI got it to work about 20% of the time. So the scrolling is maybe making the monitor more likely to sync?
It appears to be a boundary condition with WAITVID where it is not displaying what it is supposed to be displaying
I uploaded the v1.01 object into the first post.
