PST Characters
I am trying to use the Parallax Serial Terminal--and getting strange characters.
Attached is the program that I think should produce lines of "testing".
Any suggestions.
Any suggestions.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
It says that the crystal is a 5MHz one with a PLL multiplier of 16 for 80 MHz operation
John Abshier
Thank you. It fixed everything!!!!!!!!!
Larry
You know, looking at that screenshot it almost looks like we could write an adaptation of PST that would run without the Crystal. Those look like consistent characters.
OBC
http://forums.parallax.com/showthread.php?129795-FullDuplexSerial-communication-problems
Seems to be the same problem. And ... @Oldbit ... in one of the posts it's mentioned ... you simply have to compensate the deviation of the internal clock to the theoretical clock by starting the serial object with a different baudrate having the same deviation to the wished baudrate in opposite direction.
That's a good idea about having PST using the Prop's internal clock. You could enter a series of "U" characters or some other character with an easy to recognize bit pattern (ASCII "U" is %01010101). Once the pattern is recognized the Prop could change its baud to match the terminals baud.
I don't know if I have time to do this today, but I'll put it on my todo list.
This would be useful on battery operated devices that use the Prop's slow internal clock.
Duane
OBC
