Minor problem with PASD_077:
So recently I've started having this weird problem using PASD. I'm able to work around it, but I'm curious if anyone has seen something similar and knows the cause.
In short, the problem is that PASD is not counting its own initial itty-bitty kernel at the start of the module, and so it thinks the code begins at address 1 rather than address $0C or whatever it is like it should, meaning that all its ideas about offsets are wrong, and it doesn't show the proper line for execution.
The workaround I figured out was to stick dummy labels in front of each line of LONGs in the PASD kernel at the top of the module, and then PASD seems to do the calculation just fine.
Example beginning of a module:
If I don't add some labels in front of each those "long"s, PASD will be very confused. Anyone else seen this?
DAT
org
entry
' --------- Debugger Kernel add this at Entry (Addr 0) ---------
long $34FC1202,$6CE81201,$83C120B,$8BC0E0A,$E87C0E03,$8BC0E0A
long $EC7C0E05,$A0BC1207,$5C7C0003,$5C7C0003,$7FFC,$7FF8
mov addr, par
rdlong _delay, addr ' Get number of clocks to delay between each crossfade step
add addr, #4
rdlong _steps, addr ' Get number of steps in the crossfade
add addr, #4
So please don't write anything at first column if it is not a label, no IF_XXX no ORG no LONG ... (I have seen all of these before).
Andy
