470 Ohms.
Hi all,
A really stupid question:
My son was looking in my "What's a microcontroller" and at page 43, Lights on lights off, He sees a 470 Ohms resistor with a LED. Even when using a Stamp pin (Page 48) same thing 470.
In nowhere in the book it explains how did they get that number and why.
To my nooby look, I don't even know myself...
So how did 470 came up?
Cheers
Yoshti
Cheers
Yoshti
The E12 series breaks say the 100ohm to 1000 ohm space into 12 logarithmically even gaps, and 470 happens to be close to 8/12 of the way through that log space.
I have a female cousin who looks at resistors for their jewellery potential, and cannot understand why they didn't decide on values based on the colours instead
Here's a link that explains it well
http://services.eng.uts.edu.au/pmcl/ae/Downloads/Lecture04.pdf
That said, why they chose 470 Ohm instead of something smaller or larger is a question that only the manual authors can answer. It's probably a value that provides an optimum balance of circuit protection and led brightness. Or it could just be that 470 Ohm resistors were on sale when they bought them.
This leads to why limit the LED to 1/100th of an amp?
The reason is destructive heat from a combination too much current and a given voltage. You can run an LED at higher current and/or voltage, but too much higher and it burns up eventually. We all know about burnt out light bulbs, don't we? With the right limit to current an LED for a certain regulated voltage can last much longer, maybe forever.
Also consider that the amount of destructive heat is related to a number, Watts - which indicates how much power is being used. P = I x V And so 5 volts times .01 amps (10 milliamps) equals .05watts or 50 milliwatts.
So you see, an LED is a 50 milliwatt light bulb and needs to be protected from too much power - voltage and resistor size can vary, but one must limit the watts to protect the device.
And of course, you can ask how many 50 milliwatt light bulbs does it take to make one 50 watt light bulb? This will give your boy an appreciation for both math and the LED's ability.
Well, to me, taking into account the forward voltage at 1.5v for the LED.
5-1.5 = 3.5 v
Lets put the Amps at 20mA
So, my R is 3.5 /.02 = 175
Looks like I'm all wrong...
Even at I=3.5/470 =.007
What the heck??? 7mA ?
Need to go back to square one... makes no sense...
Cheers
Yosh
3.5 / 0.02
175 Ω
Do you have an idea idea, why they used 470 instead of 175?
All I can think of, is to OVER protect the STAMP PIN. Would that be a fair statement?
Cheers
Yosh
1) The led won't be as bright. Some LEDs can be blinding/very distracting.
2) The led will probably live longer the further you are from driving it on the edge.
3) I often just use a 470 ohm (or 330 ohm) resistor when I'm doing something quick/temporary without doing any calculations (or even looking up the specs of the led) because I know that the led will probably be ok with this value.
Great, thanks...
Its all I wanted to know.
I'll use this , as my rule of thumb.
Cheers
Yosh
Regarding using 470ohm as a fall back value,
I find that if I have a blinking light, it is often hard to see with older LEDs that demand more power.
Blinking brings into play the whole concept of 'duty cycle' and 'averages of voltage, current, and power'',
For 5 volts, my usual starting point for LEDs is 330 ohm, and for 3.3 volts it is 220 ohms.
I still think it is very important to get started early with presenting Watts - some people never grasp their importance and become very frustrated with their inability to build anything stable.
I agree wholeheartedly with this idea. I want to emphasize that when I say I use 470 or 330 ohm it's for convenience and based on experience but it's not the best approach to take.
Between things I've made and purchased, I have so many leds on different devices that I don't have to turn on my lights
