PropBASIC code issue and general questions
I have just started programming in PropBASIC, and am having a few issues.
I have a simple piece of code (I think) that is an on/off timer. The main code is the display portion (4-bit LCD connection), it then launches a cog for actually turning a relay on/off, and a cog that looks for button inputs to change the timer values.
Currently, my "off time" keeps decrementing by 1, in what looks like less than a second. If I comment out line 384 (WRLONG to put decremented value back in hub memory), the decrementing stops. All the other up/dn buttons work fine.
I have tried changing the input PIN, removed the input PIN entirely, grounded the input PIN. I don't think it is a wiring issue. btw- buttons are wired like on page 133 of the propeller education kit labs book.
3.3v
button
100ohm
PINx
10k ohm
GND
I'm at a bit of a loss here. I am guessing that it is something simple that I either overlooked with tired eyes, or a fundamental issue with how I am trying to do it.
Also-- can someone explain:
1) Cog variables -- what happens when you have a SUB call a SUB? I assume that they both cannot use the same temporary variable names, or strange things happen? (Variables are local to a cog, not a SUB, right?)
2) What exactly are the __tempx variables? Are they unique in a SUB? Is it a long? Can it be used as a temporary string?
3) Any other __xxxxx variables I should be aware of?
If anyone wants to look at the code, that would be great. I am also open to suggestions on how to code more efficiently, so suggest at will! (Guessing that this being one of my first programs, I am probably doing at least one thing "the hard way" if not "the wrong way."
*** NOTE: Code moved down a few entries, cleaned it up a little, still having issues. ***
Thanks!
bill
3.3v
button
100ohm
PINx
10k ohm
GND
Thanks!
bill
2) The __tempx variables are used by PropBasic commands. They are also global to the cog.
3) __paramx variables are used to pass parameters to subroutines. You can use them as a temporary variable if you don't call a subroutine when using them.
Bean
As in they are reserved, or I may use them in a SUB (as long as I do not use the same one in another SUB I call from a SUB)?
So basically, the __tempx and __paramx variables are really the same thing (undefined variables that you can use), except the __paramx has the added feature of auto-filling when you give arguments to a SUB call?
Any chance you want to give my code a quick once-over? I am also looking to make sure that I am doing things cleanly, as well as fix the variable decrementing issue...
thank you
bill
Some memory or variable allocation issue that I missed?
DEVICE P8X32A, XTAL1, PLL16X ' 1st overnight test at PLL4X good and 5 sec pause between display iterations XIN 5_000_000 ' ---------------------------------------------------------------------- ' Constants ' ---------------------------------------------------------------------- ' ---------------------------------------------------------------------- ' I/O Pins ' ---------------------------------------------------------------------- LCDRS PIN 0 LOW LCDRW PIN 1 LOW LCDE PIN 2 LOW LCDDB7 PIN 7 LOW LCDDB6 PIN 6 LOW LCDDB5 PIN 5 LOW LCDDB4 PIN 4 LOW LCDDB PIN 7..4 LOW LED PIN 17 OUTPUT btn1ontimedn PIN 12 INPUT btn1ontimeup PIN 13 INPUT btn1offtimedn PIN 14 INPUT btn1offtimeup PIN 15 INPUT OUTP1 PIN 16 LOW btn2ontimedn PIN 20 INPUT btn2ontimeup PIN 21 INPUT btn2offtimedn PIN 22 INPUT btn2offtimeup PIN 23 INPUT OUTP2 PIN 24 LOW ' ---------------------------------------------------------------------- ' Shared (hub) Variables (Byte, Word, Long) ' ---------------------------------------------------------------------- tempstr HUB STRING(4) ' Temporary value when using STR to display numbers timeon HUB LONG(10)=0 ' Timer on time (timer#) timeoff HUB LONG(10)=0 ' Timer off time (timer#) timecycles HUB LONG(10)=0 ' Total cycles completed (timer#) ' ---------------------------------------------------------------------- ' Shared (hub) Data (DATA, WDATA, LDATA, FILE) ' ---------------------------------------------------------------------- ' ---------------------------------------------------------------------- ' TASK Definitions ' ---------------------------------------------------------------------- btns TASK outputs1 TASK outputs2 TASK heartbeat TASK ' ---------------------------------------------------------------------- ' Cog Variables (Long only) ' ---------------------------------------------------------------------- x VAR LONG ' Main display loop, lcd x position y VAR LONG ' Main display loop, lcd y position maintemp VAR LONG ' Main display loop, temp variable for rdlong and wrlong pushbytex VAR LONG ' SUB pushbyte temp variable pushbytey VAR LONG ' SUB pushbyte temp variable pushbytez VAR LONG ' SUB pushbyte temp variable xpos VAR LONG ' SUB LCDpos temp variable ypos VAR LONG ' SUB LCDpos temp variable cmd VAR LONG ' SUB LCDpos temp variable cols VAR LONG ' SUB LCDpos temp variable lcdprintx VAR LONG ' SUB LCDprint temp variable ' ---------------------------------------------------------------------- ' SUB/FUNC Definitions ' ---------------------------------------------------------------------- LEDblink SUB 1 LCDenable SUB 0 LCDpushnibble SUB 1 LCDpushbyte SUB 1 LCDdigitalwrite SUB 1 LCDcommandwrite SUB 1 LCDcommandwritenibble SUB 1 LCDprint SUB 1 LCDprintstr SUB 1 LCDcls SUB 0 LCDinit SUB 0 LCDpos SUB 2 ' ====================================================================== PROGRAM Start ' ====================================================================== Start: LCDinit WRLONG timeon(1),5 WRLONG timeoff(1),15 WRLONG timeon(2),2 WRLONG timeoff(2),1 COGINIT outputs1, 1 COGINIT outputs2, 2 COGINIT btns, 5 COGINIT heartbeat, 6 LCDpos 1,1 LCDprintstr "Dev:" LCDpos 2,1 LCDprintstr "On:" LCDpos 3,1 LCDprintstr "Off:" LCDpos 4,1 LCDprintstr "Cyc:" Main: DO y=6 FOR x = 1 to 2 tempstr = STR x,6 LCDpos 1,y LCDprintstr tempstr RDLONG timeon(x),maintemp tempstr = STR maintemp,6 LCDpos 2,y LCDprintstr tempstr RDLONG timeoff(x),maintemp tempstr = STR maintemp,6 LCDpos 3,y LCDprintstr tempstr RDLONG timecycles(x),maintemp tempstr = STR maintemp,6 LCDpos 4,y LCDprintstr tempstr y = y + 7 NEXT PAUSE 500 LOOP END ' ---------------------------------------------------------------------- ' SUB/FUNC Code ' ---------------------------------------------------------------------- { SUB LEDblink b=__param1 LOW LED for i = 1 to b HIGH LED PAUSE 100 LOW LED PAUSE 250 NEXT PAUSE 1000 ENDSUB } SUB LCDpos xpos = __param1 ypos = __param2 - 1 cols = 20 IF xpos = 1 THEN cmd = 128 + ypos ENDIF IF xpos = 3 THEN cmd = 128 + ypos cmd = cmd + cols ENDIF IF xpos = 2 THEN cmd = 128 + ypos cmd = cmd + cols cmd = cmd + cols cmd = cmd + cols cmd = cmd + 4 ENDIF IF xpos = 4 THEN cmd = 128 + ypos cmd = cmd + cols cmd = cmd + cols cmd = cmd + cols cmd = cmd + cols cmd = cmd + 4 ENDIF LCDcommandwrite cmd PAUSE 1 ENDSUB SUB LCDinit PAUSE 1000 LCDcommandwritenibble %0011 ' sequence to put in 8-bit mode PAUSE 10 LCDcommandwritenibble %0011 ' sequence to put in 8-bit mode ' PAUSE 1 ' LCDcommandwritenibble %0011 ' sequence to put in 8-bit mode ' PAUSE 1 LCDcommandwritenibble %0010 ' sequence to put in 4-bit mode, repeat twice PAUSE 1 ' LCDcommandwritenibble %0010 ' sequence to put in 4-bit mode, repeat twice ' PAUSE 1 LCDcommandwrite %00101000 ' 4-bit, display lines, font, null, null PAUSE 5 ' LCDcommandwrite %00001110 ' cmd, display on, cursor on, blink off LCDcommandwrite %00001111 ' cmd, display on, cursor on, blink on PAUSE 5 LCDcommandwrite %00000110 ' entry mode, increment right, do not shift display PAUSE 5 LCDcls ' LCDpos 1,3 ' LCDprintstr welcome1 ' PAUSE 1000 ' LCDpos 3,1 ' LCDprintstr welcome2 ' PAUSE 3000 ' LCDcls ENDSUB SUB LCDcls LCDcommandwrite %00000010 LCDcommandwrite %00000001 pause 20 ENDSUB SUB LCDprintstr __param2 = __param1 ' LCDprint uses __param1 DO RDBYTE __param2, __param3 IF __param3 = 0 THEN EXIT LCDprint __param3 INC __param2 ' PAUSEus 500 LOOP ENDSUB SUB LCDprint lcdprintx = __param1 HIGH LCDRS LOW LCDRW LCDpushbyte lcdprintx ENDSUB SUB LCDcommandwrite LOW LCDRS LOW LCDRW LCDpushbyte __param1 ENDSUB SUB LCDcommandwritenibble LOW LCDRS LOW LCDRW LCDpushnibble __param1 ENDSUB SUB LCDpushbyte pushbytex = __param1 pushbytez = pushbytex & $0F pushbytey = pushbytex SHR 4 LCDpushnibble pushbytey LCDpushnibble pushbytez ENDSUB SUB LCDpushnibble LCDDB = __param1 PAUSEus 100 LCDenable ENDSUB SUB LCDenable PAUSE 1 PULSOUT LCDE, 1 ' 5 was working for a long time PAUSE 1 ENDSUB ' ---------------------------------------------------------------------- ' ====================================================================== ' TASK Code ' ====================================================================== TASK btns a VAR LONG DO IF btn1ontimedn = 1 THEN RDLONG timeon(1),a a = a - 1 if a < 1 then a = 0 endif WRLONG timeon(1),a ELSEIF btn1ontimeup = 1 THEN RDLONG timeon(1),a a = a + 1 if a < 1 then a = 0 endif WRLONG timeon(1),a ELSEIF [highlight]btn1offtimedn = 0 THEN RDLONG timeoff(1),a a = a - 1 if a < 1 then a = 0 endif WRLONG timeoff(1),a ' COMMENTING THIS OUT STOPS THE ISSUE (but then button does not work) [/highlight] ELSEIF btn1offtimeup = 1 THEN RDLONG timeoff(1),a a = a + 1 if a < 1 then a = 0 endif WRLONG timeoff(1),a ENDIF PAUSE 500 LOOP ENDTASK TASK outputs1 b VAR LONG DO RDLONG timeon(1), b __temp1 = b * 1000 HIGH OUTP1 PAUSE __temp1 RDLONG timeoff(1), b __temp1 = b * 1000 LOW OUTP1 PAUSE __temp1 RDLONG timecycles(1), b b = b + 1 WRLONG timecycles(1), b LOOP ENDTASK TASK outputs2 value VAR LONG DO RDLONG timeon(2), value __temp1 = value * 1000 HIGH OUTP2 PAUSE __temp1 RDLONG timeoff(2), value __temp1 = value * 1000 LOW OUTP2 PAUSE __temp1 RDLONG timecycles(2), value value = value + 1 WRLONG timecycles(2), value LOOP ENDTASK TASK heartbeat DO PAUSE 250 TOGGLE LED LOOP ENDTASK
TASK btns DO IF btn1ontimedn = 1 THEN ... ELSEIF btn1ontimeup = 1 THEN ... ELSEIF btn1offtimedn = 0 THEN ... ELSEIF btn1offtimeup = 1 THEN ... ENDIF PAUSE 500 LOOP ENDTASK
a) I knew it would be something simple.
b) That was left over from debigging why it was happening.
thank you!!
bill
The __tempx variables will be used by PropBASIC commands, __paramx variables are ONLY used by subroutine calls.
Bean
