Power on reset / reset circuit help
John Abshier
Chip is a MCP23008 I2C IO expander on a Propeller Professional Development Board. Power and reset (active low) are wired to the 3.3 volt supply. Problem: You can turn the power switch off, wait 5 minutes and the MCP23008 will not reset because power has not dropped enough for power on reset. Voltage for POR typical value is Vss. Min and Max not specified. One solution would be to put a resistor between 3.3 volts and ground. The down side to this solution is that it draws power all the time--not good for battery powered apps. I cannot think of a circuit that would pull the reset line low and then high on power up.
John Abshier
John Abshier
Tie /reset to 3.3V supply with a resistor, 10K or so, and then also tie /reset to ground with a 0.1uF capacitor.
The capacitor pulls /reset low briefly on power up. Might need to tweak the values a bit, but those should be in the ballpark.
C.W.
The description that was given sounds like /reset is tied directly to the 3.3V supply, so it is rising above the threshold before the chip is fully powered. The resistor/capacitor circuit should hold it low long enough.
C.W.
I highly recommend supervisor chips. They're cheap and much more reliable than the usual cap/resistor/diode approach. They provide a fixed delay, regardless of how long the power has been off. No more "waiting for the bits to settle" to get a clean reset.
I don't see the MCP23008 on the PPDB schematic, I think it is being added by the poster. I agree about using the supervisor if there are going to be more chips that have resets in the overall solution,
C.W.
