Serial Objects for SPIN Programming
A List of Serial Objects for SPIN Programming
Tired of endlessly looking for the serial object you need? This list bypasses the limited OBEX-search function and lists the primary serial objects along with their specific links, authors, and information. Includes SPIN objects and one parallel object. Includes special serial objects, some customized, from posts which may not be in the OBEX.
Simple Serial by Chip Gracey - Parallax
http://obex.parallax.com/objects/183/
Bit-bang serial driver for low baud rate (~19.2K) devices. * This driver is designed to be method-compatible with the FullDuplex serial object, allowing it to be used when high speed comms or devoting an independent cog for serial I/O is not necessary. * Bi-directional communication on the same pin is also supported.
Faster Simple Serial with Parity by Marc Gebauer
http://forums.parallax.com/showthread.php?109781-Faster-Simple-Serial-with-Parity
I had·the use for a serial driver that would do 38400 BAUD, 8 bit, even·parity and would'nt use a cog. I didn't need full duplex operation, so I played around with Simple_Serial. Here it is. I call it Fast_Simple_Serial. I have tested send and receive·from 300·to 38400 BAUD with no-parity, even-parity, and odd-parity. Note, the receiver ignores the parity bit. I have added a Demo object that was written for the Propellor Demo Board·which sends and receives to and from the USB FTDI Serial Port and is intended to·connect·with Hyperterminal. Basically when you type on the keyboard in Hyperterminal, the keys are echo'd back.
Full Duplex Serial by Chip Gracey - Parallax
http://obex.parallax.com/objects/54/
Full duplex asynchronous serial object. It will do 115,200 and has 16 byte buffers.
Modified Tim Moore's 4 port driver By Juergen Buchmueller
http://forums.parallax.com/showthread.php?128184-Serial-Objects-for-SPIN-Programming&p=962912#post962912
See post #7 on this thread's page
supports only two ports but with bigger buffers - big enough for an xmodem packet. (64 bytes increased to 256 bytes).
Extended Full Duplex Serial by Martin Hebel
http://obex.parallax.com/objects/31/
Extends out FullDuplexSerial to allow reception of character strings that end in a carriage return for decimal, hexadecimal and alpha-numeric uses. Allows use of timeout values. This version also allows use of defined delimiter characters, and returning whole and fractional portions of a numeric string.
FullDuplexSerial_rr004 by Cluso99
http://obex.parallax.com/objects/570/
FullDuplexSerial object v1.2 with modification to allow easy resizing of buffers 8/16/32/64/128/256 by specifying size in CON section of code only. (Does not do 512)
FullDuplexParallel by Terry E Trapp, KE4PJW
http://obex.parallax.com/objects/644/
This is the FullDuplexParallel object v1.0. It is based on the FullDuplexSerial object v1.1 from the Propeller Tool's Library folder with modified documentation and methods for converting text strings into numeric values in several bases. It interfaces the propeller with the FTDI FT245 Parallel FIFO. The FTDI FT245 allows for high performance I/O to a PC.
FullDuplexSerial_mini.spin by Rkrasowski
Stuff commented out which is not used.
http://forums.parallax.com/showthread.php?129460-Not-enough-COGs
http://forums.parallax.com/attachment.php?attachmentid=78079&d=1297305158
Fast 250Kbps fullduplexserial obex object by Clock Loop
http://forums.parallax.com/showthread.php?120273-Inter-Propeller-communication
http://forums.parallax.com/showthread.php?p=820293
Full Duplex Serial Port Driver by Kwabena W. Agyeman
http://obex.parallax.com/objects/397/
A full duplex serial port driver that runs on one cog. The code has been fully optimized with a super simple spin interface for maximum speed and is also fully commented. Provides full support for: Receiving bytes, Receiving strings, Transmitting bytes, Transmitting strings, Baud Rate from 1 BPS to 250,000 BPS - Full Duplex. This driver has a 256 byte receiving FIFO buffer. This driver has a 256 byte transmitting FIFO buffer.
Full duplex 8.42 MegBaud output to parallax serial Terminal demo by Clock Loop. Thread here Download here You can force error packets if you lift the 10k resistor on the rx pin.
(14.5 Meg Baud) High Speed Prop-to-Prop Serial Communication by Beau
http://forums.parallax.com/showthread.php?99222-Propeller-DEMO-%2814.5-Meg-Baud%29-High-Speed-Prop-to-Prop-Serial-Communication
http://forums.parallax.com/showthread.php?p=694610
I have run this DEMO and tested over 100 Billion data Bits with no Transmission Errors over the distance of 10 feet from one Propeller to another Propeller. “14.5 Meg Baud Upgrade using 4 I/O Pins.... This is still work in progress.· Using only 1 COG for the Transmitter, and 1 COG for the Receiver, 14.5 Mega Baud Communication Packets can be achieved. With slight modification to the "Transmitter" (using 1 COG) and "Receiver" (using 2 COGs ; 180 deg out of phase) 29 Mega Baud communication packets should be achieved through the current implementation of 4 - I/O pins. The current demo sends pseudo random Packets with a length of 32768 bits in approximately 2.25mS (<-14.5Mega Baud) at a repetition rate of 174 Hz effectively providing a constant throughput of 5.7 Mega Baud.· Keep in mind that the 174 Hz is deterministic of the overhead required for the display and Packet confirmation.· Also, the demo provides a "real time" visual representation of the Transmitter's I/O state displayed on the·Receiver screen.
SerialMirror by Mirror
http://obex.parallax.com/objects/189/
A FullDuplexSerial enhancement that allows a single serial connection to be used from within multiple spin files. Primarily aimed as a debugging aid, this file also illustrates how to use the DAT section to make single-instance objects which may be called from multiple spin files. This objects allows relatively easy change of Rx and Tx buffer sizes to the various powers of 2.
MultiCogSerialDebug by Peter Verkaik
http://obex.parallax.com/objects/232/
Derived from SerialMirror V07.05.10 All printing (also from multiple COGs) is done using cprintf. Each cprintf call is a message. The more parameter in cprintf lets you prohibit that the message is interleaved with text from another COG. To keep output clear, end each (compound) message with a \r or \r\n. Receiving should be done by a single COG that can dispatch received messages. See the test program for detailed usage.
Multiple serial port driver by Tim Moore
http://obex.parallax.com/objects/340/
Supports upto 4 serial ports with 1 COG. Also supports hardware flow control on any of the ports.
Tim Moore's pcFullDuplexSerial4FC with larger rx buffer by Duane Degn
http://forums.parallax.com/showthread.php?129714-Tim-Moore-s-pcFullDuplexSerial4FC-with-larger-rx-buffer
pcFullDuplexSerial4FCex.spin uses one cog to control up to four serial ports. After studying the code for a while, I saw how Tim reused the variable space in the hub after the cog is launched. After tracking down which variables were used by both Spin and PASM and which ones were only used within the cog, I realized there was even more space that could be reclaimed. At the cost of three longs, I was able to double the rx buffer from 64 byte per port to 128 bytes per port.
JDCogSerial by Carl Jacobs
http://obex.parallax.com/objects/398/
A full duplex serial that has *ALL* the buffer memory stored in the COG. The VAR footprint is tiny at only 6 longs. The buffer pointers are fully automatic, which allows easy access from assembly as well as sub-objects. The buffer sizes may be set at any number of bytes (in multiples of 4) to the total spare capacity of the COG (a bit over 1300 bytes). Only mode 0 is supported, with baud rates to above 345600 for a 80MHz clock.
Parallax Serial Terminal by Jeff Martin - Parallax
http://obex.parallax.com/objects/457/
This object works with the Parallax Serial Terminal; see Propeller Downloads page or install Propeller Tool v1.2.6 (or newer). It includes handy methods for output/input (Char, CharIn, Str, StrIn, Dec, DecIn, Bin, BinIn, Hex, HexIn) and cursor positioning (Home, Position, NewLine, MoveLeft, MoveRight, etc.) as well as control character constants that match the function of the Parallax Serial Terminal. A demo and a "quick start" template are provided.
jm_irtxserial by Jon McPhalen
http://obex.parallax.com/objects/462/
Allows for serial transmission (up to 2400 baud) over an IR link. Compatible with output methods of simple_serial and fullduplexserial.
Half Duplex Serial Port Driver by Kwabena W. Agyeman
http://obex.parallax.com/objects/538/
A half duplex serial port driver. The code has been fully optimized with a super simple spin interface for maximum speed and is also fully commented. Provides full support for: Even parity bit generation, Even parity bit checking, Odd parity bit generation, Odd parity bit checking, Mark parity bit generation, Mark parity bit checking, Space parity bit generation, Space parity bit checking, Receiving bytes, Receiving strings, Transmitting bytes, Transmitting strings, Baud Rate from 1 BPS to 19,200 BPS - Half Duplex.
Serial Com by Aleks
obex.parallax.com/objects/356/
A communication routine loosely based on I2C with included demo programs to communicate between two Propeller IC's.
~note-> This has only been tested on the Spin Stamp, whereas this is the only propeller I have access to. It requires a CS, SDA, and CLK line to operate. I have had success communicating between the two stamps I used, and displaying the results on an LCD screen. My contact info is in the Readme.txt.
spin FD_Serial_Conf.spin by Andy
http://forums.parallax.com/showthread.php?111836-Custom-Serial&p=797716
http://forums.parallax.com/attachment.php?attachmentid=59874&d=1239071285
Here is a variation of the FullDuplexSerial object, which allows configuration of the datasize 7..9 bits, with an additional Parity bit. Also the Buffer size can easy be changed.
Fast Inter-Propeller Communication by Bobb Fwed
http://forums.parallax.com/showthread.php?117840-Fast-Inter-Propeller-Communication-Object
obex.parallax.com/objects/546/
http://forums.parallax.com/showthread.php?118076-Fast-Inter-Propeller-Communication-Features
I just tested it at 100MHz and got a throughput of 1.37MB/s (including all overhead). Also tested at 80MHz producing 1.10MB/s. It has been tested with over a meter of wiring between two Propellers, but i can't see why it wouldn't work with much longer wires.
[POC] single wire high speed serial link (updated 20101124) by kuroneko
http://forums.parallax.com/showthread.php?110325-POC-single-wire-high-speed-serial-link-%28updated-20101124%29
FastSerial by Peter Jakacki
http://forums.parallax.com/showthread.php?114492-Prop-Baudrates
Half-duplex high speed precision serial driver. Adapted from FullDuplexSerial, This driver dedicates a cog to either receiving or transmitting serial data in a half-duplex fashion. The aim is to have precise bit timing which is important at high-speeds at and above 115K baud. The transmit routines have been to tested to 1Mbit and the receive routines work at 1Mbit
HighSpeed Serial Tx (3Mbps) / Rx (2Mbps) + autobaud for FT232R/Prop GPL by Stephen Moraco
http://forums.parallax.com/showthread.php?102696-HighSpeed-Serial-Tx-%283Mbps%29-Rx-%282Mbps%29-autobaud-for-FT232R-Prop-GPL&p=720623
This is a set of block-send and block-receive routines.· That is they are designed to reduce communication between cogs by only transporting data between them on buffer-full or line-end events.
Other Communication Software & Techniques
Full-speed (12 Mb/s) bit-banging USB Host controller by Scanlime
http://forums.parallax.com/showthread.php?121321-Working-full-speed-%2812-Mb-s%29-bit-banging-USB-Host-controller
So far it supports Control, Bulk IN/OUT, and Interrupt IN transfers. There are a couple simple demos included: Device enumeration and descriptor parsing, a very simple HID demo, and an even simpler mass storage demo. As you'd expect, there is a huge list of caveats for something that pushes the limits of the Propeller and the USB spec to this extent.. It uses four cogs, requires overclocking the Prop to 96 MHz, and even though the line rate is 12 Mb/s the actual usable data throughput is significantly lower. But, this lets you talk to a lot of fun new peripherals that were previously unavailable to the Propeller. So it should be fun
XModem receive routine for use with CP/M by Mike Green
http://forums.parallax.com/showthread.php?114023-Sphinx%E2%80%94as-seen-at-UPEW!/page10
It uses a simple checksum even though there's a CRC variable. The return value is the length of the file received.
BS2 Functions Communications by Juffra
5Mbit/sec ASCII Streaming from/to Hub RAM by Pjv
http://forums.parallax.com/showthread.php?120125-5Mbit-sec-ASCII-streaming-from-to-Hub-RAM&p=882980
Inter cog communications in Spin by SRLM
http://forums.parallax.com/showthread.php?109427-Inter-Cog-Communication
Inter cog communications in Assembly by Mctrivia
Variable access across cogs by StefanL38
Faster Inter-Propeller Communication by Synapse
http://forums.parallax.com/showthread.php?128714-Fast-Inter-Propeller-Communication
Useful 1-Wire Routines by Cam Thompson
http://obex.parallax.com/objects/18/
Special Comments by Mike Green
http://forums.parallax.com/showthread.php?129357-BS2_Functions.spin-Timing-question
The routines in BS2_Functions.spin are written for the general case and are written completely in Spin without any use of assembly language. Spin is interpreted and while much faster than the BS2 equivalent operations, is much slower than assembly language. For example, a serial input/output routine completely written in Spin will operate up to 19.2KBps with an 80MHz Propeller system clock (5MHz crystal * 16 with the PLL multiplier). The equivalent using an assembly language low-level serial I/O routine (FullDuplexSerial) can go well over 230KBps at 80MHz. The same sort of thing is true for clocked serial I/O (SHIFTIN / SHIFTOUT), but more so. The Spin routines are comparable to the asynchronous serial versions, but, using assembly and some other features (like the cog counters), you can easily get 10MHz clock speeds. There have been some special purpose serial I/O routines written (for Prop to Prop communications) that operate at 20MHz with an 80MHz system clock.
Tweaks and Experiments by Lawson
jm_txrx_demo_tweeked.zip
termv19b.zip
Multiple Instances of Full Duplex Serial Interfacing
http://forums.parallax.com/showthread.php?129464-Multiple-instances-of-Full-Duplex-Serial-interacting
For C-Like Language functions Using Spin
cserial.spin As noted by Dave Hein
http://forums.parallax.com/showthread.php?121206-cserial
cserial.spin
cserial_test.spin
It's not written in C. It's written in Spin. It's part of the CLIB object, which provides C-like functions for Spin programs. However, cserial itself does not have any C attributes. This is part of the CLIB object in the OBEX. It is yet another modified version of FDS that does not use VAR variables, but either uses buffers that are defined in DAT or buffers that are provided by the calling program, in which case it uses a handle to reference them. The bufferes can be any power of 2 in size, and the rx and tx buffers can be different sizes. There is an additional feature where an instance can be protected by a lock to make it cog-safe. I included all of the old routines of FullDuplexSerial for compatibility, and I added new versions that require a device handle.· The new versions use the same name, but with a 1 added.· As an example, the new version of str is str1.
· - Multiple serial ports may be started from any object or cog
· - Any serial port is accessable from any object or cog using a device handle
· - Transmit and receiver buffers can be different sizes
· - Buffer sizes are defined by calling parameters
· - Mode bit 4 enables the use of a lock to make the transmit multi-cog safe
The cserial.spin object in CLib can handle multiple cogs.· You call it the same way you would call the FullDuplexSerial methods, except you set bit 4 in the mode flag to make it·cog-safe.· You would call the start·function as follows: fd.start(31, 30, %10000, 115200)
The·start method·should only be called once, normally from cog 0 in the top object.· Check out the test program in CLib.· I have several cogs waiting on the same flag, and then they all print at the same time.
You can download CLib from the OBEX at http://obex.parallax.com/objects/594/·.
http://forums.parallax.com/showthread.php?122169-Ho-to-reuse-FullDuplexSerial-from-multiple-COGs-RESOLVED-use-cserial
Send information to a computer using the FullDuplexSerial object
http://forums.parallax.com/showthread.php?129795-FullDuplexSerial-communication-problems
Thread by Mlanting
In order to do serial communication you need a clock calibrated more accurately than what the internal oscillator is. You need to use an external crystal.
rxSerialTest-bst-archive-110630-121933.zip by Tracey Allen
Remarkable lowest current drain (1mA) RX communications code
http://forums.parallax.com/showthread.php?128184-Serial-Objects-for-SPIN-Programming&p=1014074&viewfull=1#post1014074
I had need for receiving infrequent but unpredictable packets of data at 115200 baud, with the hitch that the system had to operate at low current. That means clkfreq=5MHz if possible. The attached program rxSerial_ta_10.spin works for this. It is receive-only with an intrinsic current drain of 1 mA. Other programs that I tried, even those that were not rx-only, would not reach 115200 for general purpose buffering to hub ram at clkfreq=5MHz. Most talk has been about high speed, not low current. The problem is really the same as receiving at 1.8 megabaud with an 80MHz clkfreq (I = 16 mA). The trick was to rearrange the stuff that has to happen during the 1.5 bit times between the middle of the last data bit and the end of the stop bit, 65 clock ticks at 5MHz/115200baud. I hope this will be useful to others, and of course constructive comments are welcome.
Modified rxSerialDemo-bst-archive-110630-191917.zip by Tracey Allen
http://forums.parallax.com/showthread.php?128184-Serial-Objects-for-SPIN-Programming&p=1014272&viewfull=1#post1014272
I modified the demo for my rxSerial_ta_10. Now it can run on a single prop, with one cog sending the test data to the receiving cog under test. The transmitter is dedicated to sending a fixed string of characters pulled from cog memory over and over at the selected baud rate and at a selected interval. You can try mismatched baud rates. The rx and tx pins on the Prop are tied together and the debugging data goes out the p31 system port. This tx routine transmits with very close to one stop bit without extra for pulling the next byte from memory, and easily does 115200 on a 5MHz clock. Routines that transmit a string from spin always add a little extra time between bytes, so they are not as challenging to the receiver. I've been testing also with a logic analyzer, to visualize the event positions. You can see the position of the ready-for-start pulse wander depending on how the routine hits the hub access. It has to stay within a margin of the stop bit. rsSerial_ta_10 cut off one hub access by storing the head pointer in the cog, writing but not reading it. (Transmit is easier than receive. Most of the pasm tx routines should reach pretty high baud rates. For example JonnyMac's JM_txserial.)
JM_txserial by JonnyMac
http://www.google.com/url?sa=t&source=web&cd=1&sqi=2&ved=0CBgQFjAA&url=http%3A%2F%2Fforums.parallax.com%2Fattachment.php%3Fattachmentid%3D70747%26d%3D1275281933&rct=j&q=jm_txserial&ei=NAcOToePN7LdiAK1pY2FDg&usg=AFQjCNFmwnnl_8u-otvk1NEjeUsr-TICTA&cad=rja
True mode serial transmit driver -- with buffer
Serial Com by Aleks
termv19b.zip
cserial.spin
cserial_test.spin
Thread by Mlanting
OBJ
serial : "FullDuplexSerial"
PUB Main
serial.Start(31, 30, 0, 9600)
repeat
serial.str(string("test"))
waitcnt(clkfreq + cnt)
Serial MegBaud. (8.42 megbaud)
http://forums.parallax.com/showthread.php?99222-Propeller-DEMO-%2814.5-Meg-Baud%29-High-Speed-Prop-to-Prop-Serial-Communication&highlight=megbaud
Serial Com by Aleks
''****************************************************************** ''* Based on * ''* Full-Duplex Serial Driver v1.1 * ''* Author: Chip Gracey * ''* Copyright (c) 2006 Parallax, Inc. * ''* See end of file for terms of use. * ''* * ''* Juergen Buchmueller 2010-04-21 * ''* Modified to support 2 serial ports only * ''* Increased RX buffer size to 256 bytes each * ''* Tim Moore 2008 - 64 byte buffers x 4 ports * ''* Modified to support 4 serial ports * ''* It should run 1 port faster than FullDuplexSerial or run * ''* up to 4 ports * ''* Merged 64 byte rx buffer change * ''* Merged Debug_PC (Jon Williams) * ''* Uses DAT rather than VAR so can be used in multiple objects * ''* If you want multiple objects using this driver, you must * ''* copy the driver to a new file and make sure version long is * ''* unique in each version ''* Added txflush * ''* Optimization perf * ''* 1 port up to 750kbps * ''* 2 port up to 230kbps * ''* 3 port up to 140kbps * ''* 4 port up to 100kbps * ''* Tested 4 ports to 115Kbps with 6MHz crystal * ''* These are approx theoretical worse case you may get faster * ''* if port is active but idle * ''* Added RTS/CTS flow control * ''* * ''* There is no perf penalty supporting 4 serial ports when they * ''* are not enabled * ''* There is no perf penalty supporting CTS and RTS * ''* Enabling CTS on any port costs 4 clocks per port * ''* Enabling RTS on any port costs 32 clocks per port * ''* Main Rx+Tx loop is ~256 clocks per port (without CTS/RTS) * ''* compared with FullDuplexSerial at ~356 clocks * ''* * ''* There is a cost to read/write a byte in the transmit/ * ''* receive routines. The transmit cost is greater than the * ''* receive cost so between propellors you can run at max baud * ''* rate. If receiving from another device, the sending device * ''* needs a delay between each byte once you are above ~470kbps * ''* with 1 port enabled * ''* * ''* Size: * ''* Cog Initialzation code 1 x 8 + 4 x 25 * ''* Cog Receive code 4 x 30 words * ''* Cog Transmit code 4 x 26 words * ''* Spin/Cog circular buffer indexes 4 x 4 words * ''* Used in both spin and Cog and read/written in both * ''* directions * ''* Spin/Cog per port info 4 x 8 words * ''* Passed from Spin to Cog on cog initialization * ''* Spin per port info 4 x 1 byte * ''* Used by Spin * ''* Spin/Cog rx/tx buffer hub address 4 x 4 words * ''* Passed from Spin to Cog on cog initialization * ''* Spin/Cog rx/tx index hub address 4 x 4 words * ''* Passed from Spin to Cog on cog initialization * ''* Spin per port rx buffer 4 x 64 byte * ''* Read by Spin, written by cog * ''* Cog per port rx state 4 x 4 words (overlayed on rx buffer) * ''* Used by Cog * ''* Spin per port tx buffer 4 x 16 byte * ''* Written by Spin, read by Cog * ''* Cog per port tx state 4 x 4 words (overlayed on tx buffer) * ''* Used by Cog * ''* Cog constants 4 words * ''* A significant amount of space (4 x 16 words) is used for * ''* pre-calculated information: hub addresses, per port * ''* configuration. This speeds up the tx/rx routines at the cost * ''* of this space. * ''* * ''* Note: There are 8 longs remaining in the cog's memory, * ''* expect to do some work to add features :). * ''* * ''* 7/1/08: Fixed bug of not receiving with only 1 port enabled * ''* Fixed bug of rts not working on ports 0, 2 and 3 * ''* 7/22/08: Missed a jmpret call in port 1 and 3 tx * ''* Fixed a bug in port 3 tx not increasing tx ptr * ''* 7/24/08: Added version variable to change if need multiple * ''* copies of the driver * ''* * ''****************************************************************** CON FF = 12 ' form feed CR = 13 ' carriage return NOMODE = %000000 INVERTRX = %000001 INVERTTX = %000010 OCTX = %000100 NOECHO = %001000 INVERTCTS = %010000 INVERTRTS = %100000 PINNOTUSED = -1 'tx/tx/cts/rts pin is not used DEFAULTTHRESHOLD = 0 'rts buffer threshold BAUD1200 = 1200 BAUD2400 = 2400 BAUD4800 = 4800 BAUD9600 = 9600 BAUD19200 = 19200 BAUD38400 = 38400 BAUD57600 = 57600 BAUD115200 = 115200 PUB Init ''Always call init before adding ports Stop PUB AddPort(port,rxpin,txpin,ctspin,rtspin,rtsthreshold,mode,baudrate) '' Call AddPort to define each port '' port 0-3 port index of which serial port '' rx/tx/cts/rtspin pin number XXX#PINNOTUSED if not used '' rtsthreshold - buffer threshold before rts is used XXX#DEFAULTTHRSHOLD means use default '' mode bit 0 = invert rx XXX#INVERTRX '' mode bit 1 = invert tx XXX#INVERTTX '' mode bit 2 = open-drain/source tx XXX#OCTX '' mode bit 3 = ignore tx echo on rx XXX#NOECHO '' mode bit 4 = invert cts XXX#INVERTCTS '' mode bit 5 = invert rts XXX#INVERTRTS '' baudrate if cog OR (port > 1) abort if rxpin <> -1 long[@rxmask0][port] := |< rxpin if txpin <> -1 long[@txmask0][port] := |< txpin if ctspin <> -1 long[@ctsmask0][port] := |< ctspin if rtspin <> -1 long[@rtsmask0][port] := |< rtspin if (rtsthreshold > 0) AND (rtsthreshold < 256) long[@rtssize0][port] := rtsthreshold else long[@rtssize0][port] := 192 'default rts threshold 3/4 of buffer long[@rxtx_mode0][port] := mode if mode & INVERTRX byte[@rxchar0][port] := $ff long[@bit_ticks0][port] := (clkfreq / baudrate) long[@bit4_ticks0][port] := long[@bit_ticks0][port] >> 2 PUB Start : okay '' Call start to start cog '' Start serial driver - starts a cog '' returns false if no cog available '' rxbuff_head_ptr0 := rxbuff_ptr0 := @rx_buffer0 rxbuff_head_ptr1 := rxbuff_ptr1 := @rx_buffer1 txbuff_tail_ptr0 := txbuff_ptr0 := @tx_buffer0 txbuff_tail_ptr1 := txbuff_ptr1 := @tx_buffer1 rx_head_ptr0 := @rx_head0 rx_head_ptr1 := @rx_head1 rx_tail_ptr0 := @rx_tail0 rx_tail_ptr1 := @rx_tail1 tx_head_ptr0 := @tx_head0 tx_head_ptr1 := @tx_head1 tx_tail_ptr0 := @tx_tail0 tx_tail_ptr1 := @tx_tail1 bit_ticks_ptr0 := @new_bit_ticks0 bit_ticks_ptr1 := @new_bit_ticks1 new_bit_ticks0 := long[@bit_ticks0][0] new_bit_ticks1 := long[@bit_ticks0][1] okay := cog := cognew(@entry, @rx_head0) + 1 PUB Stop '' Stop serial driver - frees a cog if cog cogstop(cog~ - 1) longfill(@startfill, 0, (@endfill-@startfill)/4) 'initialize head/tails,port info and hub buffer pointers PUB getCogID : result return cog -1 ' PUB rxflush(port) ' Flush receive buffer repeat while rxcheck(port) => 0 PUB rxavail(port) : truefalse '' Check if byte(s) available '' returns true (-1) if bytes available if long[@rx_tail0][port] <> long[@rx_head0][port] truefalse:=-1 else truefalse:=0 PUB rxcheck(port) : rxbyte '' Check if byte received (never waits) '' returns -1 if no byte received, $00..$FF if byte ' if port > 3 ' abort rxbyte-- if long[@rx_tail0][port] <> long[@rx_head0][port] rxbyte := byte[@rxchar0][port] ^ byte[@rx_buffer0][(port<<6)+long[@rx_tail0][port]] long[@rx_tail0][port] := (long[@rx_tail0][port] + 1) & $ff { PUB rxtime(port,ms) : rxbyte | t '' Wait ms milliseconds for a byte to be received '' returns -1 if no byte received, $00..$FF if byte t := cnt repeat until (rxbyte := rxcheck(port)) => 0 or (cnt - t) / (clkfreq / 1000) > ms } PUB rx(port) : rxbyte '' Receive byte (may wait for byte) '' returns $00..$FF repeat while (rxbyte := rxcheck(port)) < 0 'PUB Lookahead(port) : rxbyte | tailvalue' returns a long with the next 4 bytes but doesn't read them (the rx_byte is actually a long) ' tailvalue := long[@rx_tail][port] ' tail value 0 to 63 ' repeat 4 ' collect 4 bytes and turn them into a long '' rxbyte := (rxbyte <<8) ' shift byte over by 1 ' rxbyte := (rxbyte <<8) + byte[@rxchar0][port] ^ byte[@rx_buffer0][(port<<6)+tailvalue] ' get value and add to current value ' tailvalue := (tailvalue +1) & $FF ' add one and cycle if >255 PUB Lookbehind(port) : rxbyte | headvalue ' takes the head and looks at the last 4 characters to come into the port headvalue := (long[@rx_head0][port] -4) & $FF' head value minus 4 and 0 to 255 repeat 4 ' collect 4 bytes rxbyte := (rxbyte <<8) + byte[@rxchar0][port] ^ byte[@rx_buffer0][(port<<6)+headvalue] headvalue := (headvalue +1) & $FF ' add one and cycle if >255 PUB tx(port,txbyte) '' Send byte (may wait for room in buffer) ' if port > 1 ' abort repeat until (long[@tx_tail0][port] <> (long[@tx_head0][port] + 1) & $F) byte[@tx_buffer0][(port<<4)+long[@tx_head0][port]] := txbyte long[@tx_head0][port] := (long[@tx_head0][port] + 1) & $F if long[@rxtx_mode0][port] & NOECHO rx(port) { PUB txflush(port) repeat until (long[@tx_tail][port] == long[@tx_head][port]) } PUB str(port,stringptr) '' Send string repeat strsize(stringptr) tx(port,byte[stringptr++]) PUB strln(port,strAddr) '' Print a zero-terminated string str(port,strAddr) tx(port,CR) PUB dec(port,value) '' Print a decimal number decl(port,value,10,0) PUB decf(port,value, width) '' Prints signed decimal value in space-padded, fixed-width field decl(port,value,width,1) PUB decx(port,value, digits) '' Prints zero-padded, signed-decimal string '' -- if value is negative, field width is digits+1 decl(port,value,digits,2) PUB decl(port,value,digits,flag) | i digits := 1 #> digits <# 10 if value < 0 -value tx(port,"-") i := 1_000_000_000 if flag & 3 if digits < 10 ' less than 10 digits? repeat (10 - digits) ' yes, adjust divisor i /= 10 repeat digits if value => i tx(port,value / i + "0") value //= i result~~ elseif (i == 1) OR result OR (flag & 2) tx(port,"0") elseif flag & 1 tx(port," ") i /= 10 PUB hex(port,value, digits) '' Print a hexadecimal number value <<= (8 - digits) << 2 repeat digits tx(port,lookupz((value <-= 4) & $F : "0".."9", "A".."F")) { PUB ihex(port,value, digits) '' Print an indicated hexadecimal number tx(port,"$") hex(port,value,digits) PUB bin(port,value, digits) '' Print a binary number value <<= 32 - digits repeat digits tx(port,(value <-= 1) & 1 + "0") PUB padchar(port,count, txbyte) repeat count tx(port,txbyte) PUB ibin(port,value, digits) '' Print an indicated binary number tx(port,"%") bin(port,value,digits) } PUB putc(port,txbyte) '' Send a byte to the terminal tx(port,txbyte) { PUB newline(port) putc(port,CR) PUB cls(port) putc(port,FF) } PUB getc(port) '' Get a character '' -- will not block if nothing in uart buffer return rxcheck(port) ' return rx PUB get_entry return @entry PUB get_tx_head return tx_head_ptr0 PUB get_tx_tail return tx_tail_ptr0 PUB get_tx_buffer return txbuff_ptr0 PUB get_rx_head return rx_head_ptr0 PUB get_rx_tail return rx_tail_ptr0 PUB get_rx_buffer return rxbuff_ptr0 PUB get_bit_ticks0 return bit_ticks_ptr0 PUB get_tx_head1 return tx_head_ptr1 PUB get_tx_tail1 return tx_tail_ptr1 PUB get_tx_buffer1 return txbuff_ptr1 PUB get_rx_head1 return rx_head_ptr1 PUB get_rx_tail1 return rx_tail_ptr1 PUB get_rx_buffer1 return rxbuff_ptr1 PUB get_bit_ticks1 return bit_ticks_ptr1 DAT '*********************************** '* Assembly language serial driver * '*********************************** ' org 0 ' ' Entry ' 'To maximize the speed of rx and tx processing, all the mode checks are no longer inline 'The initialization code checks the modes and modifies the rx/tx code for that mode 'e.g. the if condition for rx checking for a start bit will be inverted if mode INVERTRX 'is it, similar for other mode flags 'The code is also patched depending on whether a cts or rts pin are supplied. The normal ' routines support cts/rts processing. If the cts/rts mask is 0, then the code is patched 'to remove the addtional code. This means I/O modes and CTS/RTS handling adds no extra code 'in the rx/tx routines which not required. 'Similar with the co-routine variables. If a rx or tx pin is not configured the co-routine 'variable for the routine that handles that pin is modified so the routine is never called 'We start with port 3 and work down to ports because we will be updating the co-routine pointers 'and the order matters. e.g. we can update txcode3 and then update rxcode3 based on txcode3 'port 3 entry rxcode0 if_never mov rxcode0,#receive0 'statically set these variables txcode0 if_never mov txcode0,#transmit0 rxcode1 if_never mov rxcode1,#receive1 txcode1 if_never mov txcode1,#transmit1 'port 1 test rxtx_mode1,#OCTX wz 'init tx pin according to mode test rxtx_mode1,#INVERTTX wc if_z_ne_c or outa,txmask1 if_z or dira,txmask1 if_z_eq_c or txout1,domuxnc 'patch muxc to muxnc if_nz movd txout1,#dira 'change destination from outa to dira test rxtx_mode1,#INVERTRX wz 'wait for start bit on rx pin if_nz xor start1,doifc2ifnc 'if_c jmp to if_nc or ctsmask1,#0 wz if_nz test rxtx_mode1,#INVERTCTS wc if_nz_and_nc or ctsi1,doif_z_or_nc 'if_nc jmp if_nz_and_c or ctsi1,doif_z_or_c 'if_c jmp if_z mov txcts1,transmit1 'copy the jmpret over the cts test if_z movs ctsi1,#txcts1 'patch the jmps to transmit to txcts0 if_z add txcode1,#1 'change co-routine entry to skip first jmpret 'patch rx routine depending on whether rts is used 'and if it is inverted or rtsmask1,#0 wz if_nz test rxtx_mode1,#INVERTRTS wc if_nz_and_nc or rts1,domuxnc 'patch muxc to muxnc if_z mov norts1,rec1i 'patch to a jmp #receive1 if_z movs start1,#receive1 'skip all rts processing or txmask1,#0 wz ' if_z mov txcode1,rxcode2 'use variable in case it has been changed or rxmask1,#0 wz ' if_z mov rxcode1,txcode1 'use variable in case it has been changed 'port 0 test rxtx_mode0,#OCTX wz 'init tx pin according to mode test rxtx_mode0,#INVERTTX wc if_z_ne_c or outa,txmask0 if_z or dira,txmask0 'patch tx routine depending on invert and oc 'if invert change muxc to muxnc 'if oc change out1 to dira if_z_eq_c or txout0,domuxnc 'patch muxc to muxnc if_nz movd txout0,#dira 'change destination from outa to dira 'patch rx wait for start bit depending on invert test rxtx_mode0,#INVERTRX wz 'wait for start bit on rx pin if_nz xor start0,doifc2ifnc 'if_c jmp to if_nc 'patch tx routine depending on whether cts is used 'and if it is inverted or ctsmask0,#0 wz 'cts pin? z not set if in use if_nz test rxtx_mode0,#INVERTCTS wc 'c set if inverted if_nz_and_nc or ctsi0,doif_z_or_nc 'if_nc jmp if_nz_and_c or ctsi0,doif_z_or_c 'if_c jmp if_z mov txcts0,transmit0 'copy the jmpret over the cts test if_z movs ctsi0,#txcts0 'patch the jmps to transmit to txcts0 if_z add txcode0,#1 'change co-routine entry to skip first jmpret 'patch rx routine depending on whether rts is used 'and if it is inverted or rtsmask0,#0 wz 'rts pin, z not set if in use if_nz test rxtx_mode0,#INVERTRTS wc if_nz_and_nc or rts0,domuxnc 'patch muxc to muxnc if_z mov norts0,rec0i 'patch to a jmp #receive if_z movs start0,#receive0 'skip all rts processing if not used 'patch all of tx routine out if not used or txmask0,#0 wz ' if_z mov txcode,rxcode1 'use variable in case it has been changed 'patch all of rx routine out if not used or rxmask0,#0 wz ' if_z mov rxcode,txcode 'use variable in case it has been changed ' ' Receive ' receive0 jmpret rxcode0,txcode0 'run a chunk of transmit code, then return 'patched to a jmp if pin not used rdlong bit_ticks0, bit_ticks_ptr0 mov bit4_ticks0, bit_ticks0 shr bit4_ticks0, #2 test rxmask0,ina wc start0 if_c jmp #norts0 'go check rts if no start bit 'will be patched to jmp #receive if no rts mov rxbits0,#9 'ready to receive byte mov rxcnt0,bit4_ticks0 '1/4 bits add rxcnt0,cnt :bit0 add rxcnt0,bit_ticks0 '1 bit period :wait0 jmpret rxcode0,txcode0 'run a chuck of transmit code, then return mov t1,rxcnt0 'check if bit receive period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait0 test rxmask0,ina wc 'receive bit on rx pin rcr rxdata0,#1 djnz rxbits0,#:bit0 'get remaining bits jmpret rxcode0,txcode0 'run a chunk of transmit code, then return shr rxdata0,#32-9 'justify and trim received byte wrbyte rxdata0,rxbuff_head_ptr0'{7-22} add rx_head0,#1 and rx_head0,#$FF '256 byte buffer wrlong rx_head0,rx_head_ptr0 '{8} mov rxbuff_head_ptr0,rxbuff_ptr0 'calculate next byte head_ptr add rxbuff_head_ptr0,rx_head0 norts0 rdlong rx_tail0,rx_tail_ptr0 '{7-22 or 8} will be patched to jmp #r3 if no rts mov t1,rx_head0 sub t1,rx_tail0 'calculate number bytes in buffer and t1,#$FF 'fix wrap cmps t1,rtssize0 wc 'is it more than the threshold rts0 muxc outa,rtsmask0 'set rts correctly rec0i jmp #receive0 'byte done, receive next byte ' ' Receive1 ' receive1 jmpret rxcode1,txcode1 'run a chunk of transmit code, then return rdlong bit_ticks1, bit_ticks_ptr1 mov bit4_ticks1, bit_ticks1 shr bit4_ticks1, #2 test rxmask1,ina wc start1 if_c jmp #norts1 'go check rts if no start bit mov rxbits1,#9 'ready to receive byte mov rxcnt1,bit4_ticks1 '1/4 bits add rxcnt1,cnt :bit1 add rxcnt1,bit_ticks1 '1 bit period :wait1 jmpret rxcode1,txcode1 'run a chuck of transmit code, then return mov t1,rxcnt1 'check if bit receive period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait1 test rxmask1,ina wc 'receive bit on rx pin rcr rxdata1,#1 djnz rxbits1,#:bit1 jmpret rxcode1,txcode1 'run a chunk of transmit code, then return shr rxdata1,#32-9 'justify and trim received byte wrbyte rxdata1,rxbuff_head_ptr1 '7-22 add rx_head1,#1 and rx_head1,#$FF '256 byte buffers wrlong rx_head1,rx_head_ptr1 mov rxbuff_head_ptr1,rxbuff_ptr1 'calculate next byte head_ptr add rxbuff_head_ptr1,rx_head1 norts1 rdlong rx_tail1,rx_tail_ptr1 '7-22 or 8 will be patched to jmp #r3 if no rts mov t1,rx_head1 sub t1,rx_tail1 and t1,#$FF cmps t1,rtssize1 wc rts1 muxc outa,rtsmask1 rec1i jmp #receive1 'byte done, receive next byte ' ' ' Transmit ' transmit0 jmpret txcode0,rxcode1 'run a chunk of receive code, then return 'patched to a jmp if pin not used txcts0 test ctsmask0,ina wc 'if flow-controlled dont send rdlong t1,tx_head_ptr0 '{7-22} - head[0] cmp t1,tx_tail0 wz 'tail[0] ctsi0 if_z jmp #transmit0 'may be patched to if_z_or_c or if_z_or_nc rdbyte txdata0,txbuff_tail_ptr0'{8} add tx_tail0,#1 and tx_tail0,#$0F wz wrlong tx_tail0,tx_tail_ptr0 '{8} if_z mov txbuff_tail_ptr0,txbuff_ptr0 'reset tail_ptr if we wrapped if_nz add txbuff_tail_ptr0,#1 'otherwise add 1 jmpret txcode0,rxcode1 shl txdata0,#2 or txdata0,txbitor 'ready byte to transmit mov txbits0,#11 mov txcnt0,cnt txbit0 shr txdata0,#1 wc txout0 muxc outa,txmask0 'maybe patched to muxnc dira,txmask add txcnt0,bit_ticks0 'ready next cnt :wait jmpret txcode0,rxcode1 'run a chunk of receive code, then return mov t1,txcnt0 'check if bit transmit period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait djnz txbits0,#txbit0 'another bit to transmit? txjmp0 jmp ctsi0 'byte done, transmit next byte ' ' Transmit1 ' transmit1 jmpret txcode1,rxcode0 'run a chunk of receive code, then return txcts1 test ctsmask1,ina wc 'if flow-controlled dont send rdlong t1,tx_head_ptr1 cmp t1,tx_tail1 wz ctsi1 if_z jmp #transmit1 'may be patched to if_z_or_c or if_z_or_nc rdbyte txdata1,txbuff_tail_ptr1 add tx_tail1,#1 and tx_tail1,#$0F wz wrlong tx_tail1,tx_tail_ptr1 if_z mov txbuff_tail_ptr1,txbuff_ptr1 'reset tail_ptr if we wrapped if_nz add txbuff_tail_ptr1,#1 'otherwise add 1 jmpret txcode1,rxcode0 'run a chunk of receive code, then return shl txdata1,#2 or txdata1,txbitor 'ready byte to transmit mov txbits1,#11 mov txcnt1,cnt txbit1 shr txdata1,#1 wc txout1 muxc outa,txmask1 'maybe patched to muxnc dira,txmask add txcnt1,bit_ticks1 'ready next cnt :wait1 jmpret txcode1,rxcode0 'run a chunk of receive code, then return mov t1,txcnt1 'check if bit transmit period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait1 djnz txbits1,#txbit1 'another bit to transmit? txjmp1 jmp ctsi1 'byte done, transmit next byte ' 'These are used by SPIN and assembler, using DAT rather than VAR 'so all COGs share this instance of the object ' startfill cog long 0 'cog flag/id 'Dont Change the order of any of these initialized variables without modifying 'the code to match - both spin and assembler 'Dont make any of the initialized variables, uninitialized, only the initialized 'variables are duplicated in hub memory rx_head0 long 0 '16 longs for circular buffer head/tails rx_head1 long 0 rx_tail0 long 0 rx_tail1 long 0 tx_head0 long 0 tx_head1 long 0 tx_tail0 long 0 tx_tail1 long 0 'This set of variables were initialized to the correct values in Spin and loaded into this cog 'when it started rxmask0 long 0 '33 longs for per port info rxmask1 long 0 txmask0 long 0 txmask1 long 0 ctsmask0 long 0 ctsmask1 long 0 rtsmask0 long 0 rtsmask1 long 0 rxtx_mode0 long 0 rxtx_mode1 long 0 bit4_ticks0 long 0 bit4_ticks1 long 0 bit_ticks0 long 0 bit_ticks1 long 0 rtssize0 long 0 rtssize1 long 0 rxchar0 byte 0 rxchar1 byte 0 'This set of variables were initialized to the correct values in Spin and loaded into this cog 'when it started. They contain the hub memory address of the rx/txbuffers rxbuff_ptr0 long 0 '32 longs for per port buffer hub ptr rxbuff_ptr1 long 0 txbuff_ptr0 long 0 txbuff_ptr1 long 0 rxbuff_head_ptr0 long 0 rxbuff_head_ptr1 long 0 txbuff_tail_ptr0 long 0 txbuff_tail_ptr1 long 0 rx_head_ptr0 long 0 rx_head_ptr1 long 0 rx_tail_ptr0 long 0 rx_tail_ptr1 long 0 tx_head_ptr0 long 0 tx_head_ptr1 long 0 tx_tail_ptr0 long 0 tx_tail_ptr1 long 0 endfill 'used to calculate size of variables for longfill with 0 ' 'note we are overlaying cog variables on top of these hub arrays, we need the space ' rx_buffer0 'overlay rx variables over rxbuffer rxdata0 long 0 'transmit and receive buffers rxbits0 long 0 rxcnt0 long 0 rxdata1 long 0 rxbits1 long 0 rxcnt1 long 0 t1 long 0 long 0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 rx_buffer1 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 long 0,0,0,0,0,0,0,0 tx_buffer0 'overlay tx variables over txbuffer txdata0 long 0 txbits0 long 0 txcnt0 long 0 long 0 tx_buffer1 'overlay tx variables over txbuffer txdata1 long 0 txbits1 long 0 txcnt1 long 0 long 0 bit_ticks_ptr0 long 0-0 bit_ticks_ptr1 long 0-0 'values to patch the code doifc2ifnc long $003c0000 'patch condition if_c to if_nc using xor doif_z_or_c long $00380000 'patch condition if_z to if_z_or_c using or doif_z_or_nc long $002c0000 'patch condition if_z to if_z_or_nc using or domuxnc long $04000000 'patch muxc to muxnc using or ' txbitor long $0401 'bits to or for transmitting 'If you want multiple copys of this driver in a project, then copy the file to multiple files and change 'version in each to be unique version long 1 ' FIT $1F0 new_bit_ticks0 long 0-0 new_bit_ticks1 long 0-0 '' MIT LICENSE {{ ' Permission is hereby granted, free of charge, to any person obtaining ' a copy of this software and associated documentation files ' (the "Software"), to deal in the Software without restriction, ' including without limitation the rights to use, copy, modify, merge, ' publish, distribute, sublicense, and/or sell copies of the Software, ' and to permit persons to whom the Software is furnished to do so, ' subject to the following conditions: ' ' The above copyright notice and this permission notice shall be included ' in all copies or substantial portions of the Software. ' ' THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, ' EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF ' MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. ' IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY ' CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, ' TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE ' SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. }}Fast Inter-Propeller Communication by Bobb Fwed
This is a nice post. It is good to be able to look at the available options from a glance.
Bruce
Another reason the prop is great!
As it stands, it only covers fullDuplexSerial v1.2, pcFullDuplexSerial4FC, and ParallaxSerialTerminal.
Supports up to 4 serial ports with 1 COG. Also supports hardware flow control on any of the ports.
One tiny issue has to do with the spin code for outputting decimal data and has to do with the maximum negative value (NEGX). This is an issue that bumped the original fullDuplexSerial from version 1.1 to 1.2. NEGX otherwise displays as zero. In the DECL(port,value) method, think about changing
if value < 0 -value tx(port, "-")tox := value == NEGX if value < 0 value := ||(value+x) tx(port,"-")Having serial.out would allow most serial drivers to be quickly swapped with TV/VGA drivers.
"I'm sure Beau could give some tips on accomplishing this."
I'd have to get my head around it again, but one thought would still be to setup a defined master and a defined slave.
The master initially sends data while the slave receives, and then "since they are in sync" the slave becomes the transmitter on the same lines while the master listens. You could define an area of memory on each side (master and slave) that gets written to and read from. It may not be wise to share the same location for transmit or receive. The throughput would be half of the 14.5 Meg Baud, but you would in essence create a high speed bi-directional conduit between two props where data could be read or written with other cogs.
InterComm by Bruce Drummond
http://forums.parallax.com/showthread.php?129118-Looking-for-suggestions-pertaining-to-new-object
Prop to Prop custom message creation with parsing
explaining the nature of serial spin vs serial assembly and
the effects of the two combined.
http://forums.parallax.com/showthrea...-to-new-object
Bruce Drummond removed all his attached code from all his posts. Therefore, the link is removed from this list as well.
termv19b.zip
I can get your "jm_rxserial" to receive garbage too at 2_000_000 baud and 2 stop bits. With some small tweeks though I've been able to get the code working at 1_500_000 baud and 2 stop bits. (commented out a waitcnt after the ASM byte receive loop, and boosted the RX buffer)
The attached serial terminal is something I found on the 'net to let me send and receive binary bytes over rs232 without having to resort to programming. When I set it to a custom baud rate of 2_000_000 baud, type something into the transmit text box and hit send, garbage sometimes comes back. This terminal program won't do this when I tell it to "send file". My best guess is that whatever text is in the send box is dumped into the TX buffer of the FTDI chip in one block so the FTDI outputs RS232 bytes with no gaps. (setting 2 stop bits helps but won't fix this)
and
cserial.spin
