Receiving RS232 and not having to wait for input
I was wondering if there is a generally accepted way to receive RS232 input but not have to wait around for it to show up? I have a device that will transmit data when it feels like it and I am doing some other things at the same time and what to check if there is something to look at in my own time and not wait for the device to send me something. I have used a new cog to run some spin code that does just that (I think) but I was wondering if there was an easy way/object/other for this or a common method?
Here is what I am doing and please hold the giggles.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
' debug - USE onboard pins
pcDebugRX = 31
pcDebugTX = 30
pcMode = 0
CmdDebugRx = 25
CmdDebugTx = 24
' serial baud rates
pcDebugBaud = 115200
CmdDebugBaud = 9600
Var
Byte Command
long Cog[2]
long stack[132]
OBJ
Debug : "FullDuplexSerialPlus" '....added this to do sum debugging
CmdDebug : "FullDuplexSerialPlus"
ReturnCom : "GadgetRS232Com2"
PUB Start : okay
Debug.Start(pcDebugRX,pcDebugTX,pcMode,pcDebugBaud) ' start the debugger
cmdDebug.Start(CmdDebugRX,CmdDebugTX,pcMode,cmdDebugBaud) ' start the debugger
'if cog > 0
'cogstop(cog)
'cog := cognew(ReturnCom.start(pcDebugRX,pcDebugTX,pcMode,pcDebugBaud,CmdDebugRX,CmdDebugTX), @stack[0])
waitcnt(ClkFreq * 5 + cnt) 'wait a bit to give time to activate the Serial terminal
Debug.tx(13)
cog[0] := cognew(GetCmdInput, @stack[0]) + 1
waitcnt(clkfreq/2 + cnt)
cog[1] := cognew(GetPCinput, @stack[66]) + 1
' cogstop(cog[1])
' cog[1] := cognew(GetPCinput, @stack[66]) + 1
repeat
PUB GetCmdInput :count
'cmdDebug.str(string("Starting RGB control Program!", 13))
Debug.str(string("Starting RS232 OO output to PC!", 13))
CmdDebug.rxFlush
Count := 0
repeat
Command := CmdDebug.Rx
if command == 32
Debug.tx(13)
' count := 0
'count += 1
'Debug.hex(Command, 2)
Debug.tx(Command)
Command := 0
PUB SetUpOOSpec
Debug.str(string("Config OO spec!", 13))
Debug.rxFlush
repeat
Command := Debug.Rx
CmdDebug.tx(Command)
Command := 0
PUB GetPCInput : Char
Debug.str(string("Starting RS232 Com to OO spec!", 13))
Debug.rxFlush
repeat
Char := Debug.Rx
CmdDebug.tx(Char)
Char := 0
