Looking for material that will only let UV pass through
Good morning all, does anyone know of a material that will let UV (a, b or c) only light/radiation to pass through? after a few google searches, all i can find metioned is lenses for cameras, which are very expensive. im just looking for something to put in front of a uv led and use the led in reverse-bias mode as a home-brew uv sensor. any help is greatly appreciated!
http://stores.ebay.com/BJOMEJAG-EBUYER-STORE/Ultra-Violet-Filters-/_i.html?_fsub=9&_sid=8343593&_trksid=p4634.c0.m322
If you don't see what you want, you can ask him, too.
EDIT: I should add that what the ebay dude sells is also new, but they are over runs or small defective items from his manufacturing plant.
You could try using two of those LEDs and putting a UV-blocking filter (i.e. sunglass lens) in front of one of them. You will also need to come up with a way to calibrate the difference between them to come up with the UV component.
Also, I'm too lazy to look it up, but black polycarbonate may work as well.
-h
Seriously..... There are materials that will transmit UV wavelengths and block all others. Edmund Optics was already mentioned as a source for such filters. Newport Corporation is another. The problem is that these filters is they can be quite expensive. $50 or more for a 1" dia. filter is probably more than you want to pay for this project.
One possibility for a cheap solution, try a theatrical lighting suppply company. The gel filters used in stage lighting may give the solution you need. These gels come in sheets that sell for a few dollars and you can cut out the size you need. One company that makes these filters is Rosco, and they have spectra plots for all of their color filters available online. Sheets of different colors can be stacked to create bandpass filters. It will take at least 2 different sheets to get the bandpass you desire. The problem with this solution is that you may not be able to get the UV transmission you need. Most of their filters roll off steeply below 400nm.
Another alternative would be to shield the sensor from stray. A dark tube slipped over the LED will accomplish this. The sensor would then only respond to whatever it is pointed toward.
http://www.rosco.com/us/filters/roscolux.cfm#colors
That's because incandesant lights actually emit in the UV band as well as visible and IR. You won't fix it by putting a filter in front of it because of that fact.
You'll need to look at filtering the data instead.
Bill
(To Moderators, seeing how this thread has somewhat transformed into a sensor related topic, feel free to move if you think it should be.)
I may have and answer to your problem. I am working on a project now that requires only UV radiation be detected. Get back to me. Very simple and no added expense.
James Garner
You presumably want a detector that doesn't degrade in constant sunlight for years? That could be an issue in itself.
