Pinball machine interfacing question
I'm building a circuit to sense the data going into a bally 6-digit pinball display and feed it to a Propeller instead.
Details of how the displays work can be found here: http://stevekulpa.net/pinball/bally_disp6.htm
In short, the signal is fed over over 11 lines. 6 of the lines are used to indicate which one of the 6 digits is getting updated. 4 of the lines send the number in binary coded decimal. The last line is the "strobe". When the data is set up on the other 10 lines, the last line is strobed to latch the data onto that digit of the display (kind of like a parallel shift register).
My question: Will the Prop be fast enough if I have a cog watch for the strobe signal and then read the 10 data lines, or is it likely the duration of a strobe event will be too short to do this? The signals are generated from a Bally MPU board that runs at I think 1MHz. Normally the signal is fed into a 4543B BCD to 7segment latch decoder, which lists its minimum LD pulse width at 125ns.
I think my other option would be to have the strobe signal latch the data into a parallel shift register, but I'd much rather read them right into the Prop if I can. (There are actually 5 different strobe lines, one for each display.)
I don't have a 'scope to tell me the duration of the strobe signal.
Thanks in advance for your help.
Kevin
Kevin
Fron what you describe, I would think the prop would handle it (assuming 125ns strobe width) using pasm but spin will not likely get there.
bongk: Please be VERY careful. Those gas-discharge displays run at about 190 volts... we'd hate to lose you!
And the MCU boards are extremely static sensitive.
Side note: I used to repair these machines when I was in college. With just a multimeter, 10mHz logic probe, and soldering iron. I remember (and not fondly) lots of desoldering and resoldering of blown transistors and resistors on those displays.
Andre'
But, counters, 555's, flip flops, latches will all do the job in one way or another.
Andre'
Andre', you are assuming that the data lines are still valid after the strobe pulse ends. That may or may not be true. Remember that the START of the strobe is when the data is guaranteed to be available. At some point, the MCU has to prepare the data lines for the next strobe, and I would expect the MCU to begin the preparation as soon as the strobe pulse has ended.
Granted, I haven't proved this with a 'scope (mainly because I don't have access to a machine).
Therefore, it MAY be possible to do this with SPIN, using a WAITPEQ or WAITPNE instruction and then immediately reading the state of the other lines... but you are talking about a valid data window that may be as small as 20 PASM instructions... SPIN may be that fast, but hub memory access timing (which may vary) could trip you up. Use PASM to be sure (especially because you don't have a 'scope).
I think I've decided to take the safe route and use IC's to catch the data and the strobes.
I see how I can monitor one of the strobe lines with a single JK flip-flop. There are five different stobe lines (one for each display in the backglass), is there an easier solution to monitor all five than five individual JK flip-flops? I've been looking through datasheets on octal latches, etc. but haven't found a chip that looks like it will work.
Kevin
74F573 Octal Transparent Latch...Its Latch Enable input is "active falling edge, so I think I can tie all five strobes together with diodes to the Latch Enable pin, and each strobe to a data pin.
