Tiny Solderless Breadboard — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2011-02-08 05:57 in General Discussion
Where is an image drawing of this tiny solderless breadboard
that's empty, so I can use it for adding wires and making illustrations?
Thanks for you help.
MakeThumbImage.aspx?ID=%2fPortals%2f0%2fImages%2fProd%2f7%2f700%2f700-00012-M.jpg&PORTALID=0&W=120&H=120
  • TumblerTumbler Posts: 323
    edited 2011-02-06 03:04
    edited 2011-02-06 04:34
    Tumbler, that's amazing! Thanks for this great find.
    Here's a sample board I made in a minute.
    PEBBLE - the Electronic Bread Board Layout Emulator can be
    used for protyping the small Parallax solderless breadboard
    It appears this program is a fast way to image prototype boards
    for various projects. It matches the solderless breadboard used
    by Parallax. More tests and more information will appear in the
    Robotic Brain thread here.
    459 x 412 - 38K
    edited 2011-02-06 07:39
    That could be a handy program for Breadboard Prototyping...
    What's the trick to have the components display above the Breadboard when they are dropped in place?
    I was dragging and dropping components, but they just dissapear behind the breadboard.:frown:
    I did turn on the "Print background colors" in the I.E advanced options.
    Maybe it's My version of Internet Explorer?
    P.S.
    Humanoido, In Your Robotic Brain thread here., You used the spelling "Tumler", instead of "Tumbler":nerd:
    edited 2011-02-06 08:18
    Ttailspin wrote: »
    P.S.
    Hi Ttailspin, thanks for catching the typo - it's now corrected. To have the components display above the board, you can enable the workspace above (or below) the board. To have parts appear on top of the board, they just appear upon release of the mouse. You may try and see if they drop into the workspace. You must also select the version of the program (for IE or FF). The components should not disappear. I'm using version FireFox 3.6.13. Also, I did not touch the option to "Print background colors." When I tried the IE version of the program in FireFox, it still worked and I was unable to duplicate the anomaly you are seeing.
    edited 2011-02-06 08:33
    I know Your not "in charge" of this program Humanoido, and maybe Tumbler, could chime in here,
    ...You must also select the version of the program (for IE or FF)...
    I did not see this option, or where to find it to make the change..
    Am I missing the Help file?
    I am sure this is part of My IE vs FF problem, but when I try to change the location of the Menu,
    it too, will hide from Me. I can only select the menu to be on the Left side of the screen..
    Yup... that's Me allright..(sigh)
    This is going to be super handy to use, if I can get it to work with a dinasour operating system.
    edited 2011-02-06 09:08
    Ttailspin, you're right, it's not my program, however I have full confidence that we can get it working for you. Select either IE or FF when you enable program at the web site, which then takes you to the appropriate page. If you take a look at the directory, I think it uses something like Flash and you would need to have the latest version installed. You can check this at the directory by back typing on the URL. You may want to install FireFox if the OS can support it.
  • John AbshierJohn Abshier Posts: 1,116
    edited 2011-02-06 09:13
    I got it to work after changing FF to IE in the link.
    John Abshier
    edited 2011-02-06 09:17
    This stuff is so easy, it's hard...
    I changed this..
    Into this...
    Thank You for Your time Humanoido..
    Now I am free to design the next space shuttle launch and recovery system..
    Thanks John Abshier, think we just cross posted.
  • KMyersKMyers Posts: 433
    edited 2011-02-06 11:29
    Same issue here with IE. Changed the URL parts drop ok but cant scrol the menu?
  • zappmanzappman Posts: 418
    edited 2011-02-06 11:46
    What a nice program, I now have it book marked.
  • rubbersideuprubbersideup Posts: 14
    edited 2011-02-06 12:33
    omg thats neat i book marked it to
    edited 2011-02-06 13:37
    That's really slick. I see that you can pick the Gadget Gangster full and half board as the layout board instead of a breadboard. Would be nice to have the Propeller Proto Board in there too.
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2011-02-06 20:19
    For anybody interested, take a look at Fritzing and Virtual Breadboard.
    edited 2011-02-06 21:42
    Kevin Wood wrote: »
    Kevin, thanks! This is very good open source stuff! The video for Virtual Breadboard is impressive and for Fritzing, the applications page is captivating with so many projects, rich and spectacular! We definitely need open source fun tools like this for the Propeller!
    edited 2011-02-06 22:03
    ]That's a pretty slick little web application.. Shame we can't grep a copy and add some Parallax parts to it.
    I tend to do these by hand. I'd love an automated process for this..
    OBC
    424 x 369 - 47K
    411 x 419 - 47K
    edited 2011-02-07 01:07
    Fritzing has a Parallax BASIC Stamp and a Propeller chip! I started a review here.
    edited 2011-02-07 01:10
    OBC, that's some mighty fine hand-work you did! I'm impressed!
    Care to share some insight to get us beginners started in the
    right direction? I wonder what program you used to draw the
    images..
    edited 2011-02-07 10:30
    @OBC, you can download PEBBLE here: http://www.rev-ed.co.uk/software/pebble.zip and use it local.
    You can add all parallax products too, just take a look at the javascript files and add yours.
    edited 2011-02-07 12:02
    Tumbler, thanks for the tips about downloading Pebble for local use, and adding Parallax products through the Javascript files! I'd like to try it with the Piezo Speaker.
    edited 2011-02-07 12:24
    @Tumbler,
    Thank you! I'll look at that and add it to my todo list. Some Parallax products added to the list would really make it an awesome tool!
    edited 2011-02-07 12:25
    Humanoido wrote: »
    images..
    You'll laugh. I honestly use mspaint. Only because I've been using it for twenty years.
    OBC
    You'll laugh. I honestly use mspaint. Only because I've been using it for twenty years. OBC
    OBC, I'm not laughing, just smiling in good appreciation the skill level that you've developed using MS Paint over a 20 year time period.
