DIP version of Underbelly board — Parallax Forums
TubularTubular Posts: 4,774
edited 2011-02-06 09:42 in Propeller 1
This is a prototype memory board that is almost all DIP for ease of soldering. The bypass caps and uSD socket are under the board.
It mounts above the prop chip, and includes components for Audio out as well as TV out. It also has the 5v or 3v3 select jumper for the ADC.
    Is this something You are going to package into a do it Yourself Kit form?
    No Problem, I have all the solder wick I will need to assemble this board..:smile:
