Multiple foot print with Diptrace
I'm creating a circuit based on the propeller and on Diptrace.
At schematic level I can choose DIP or SMD version of the propeller, but footprint and connectivity changes a lot and it is necessary to heavily modify the schematic.
Is there an obvious way to have the double option? For instance at the moment I'm working with the DIP version. In case I'll find the package is too big, or I feel still handed, I would like to switch to an SMD version. I would like to be able to start a new layout simply changing footprint, but not modifying the schematic. Is it possible? Maybe with a sub circuit, or in a so obvious way that nonetheless eludes me?
Thanks in advance,
Massimo
Thanks in advance,
Massimo
DIP and QFP are rather different. Mainly pin mapping and number of power supply pins.
I'm wondering if it would be possible to create two subcircuits, with the same external interface, and inside the different pin number and mapping?
Maybe in the subcircuit I could add 2 or 4 decoupling capacitors, depending on the package..
Massimo
Massimo
2. Another way is making 2 hierarchy sheets. In this case you will need to replace blocks - there is sence to make similar pin arrangement in blocks for easy replacement. I would recommend the first way as much easier and obvious though.
I'll check the tutorials and play with both solutions.
Massimo
