Help finding an ESD tester circuit for real time monitoring on a bench
WBA Consulting
Once in a while I come across a something that has a high price tag without any justification. I believe I found one today: A real time ESD worksurface monitoring device. These little devices are used to monitor the grounding status of a workbench and an operator that has an ESD wrist strap plugged into it. Here's an example of a very basic one at Digikey for $261.
Anyone know what magic is going on inside that box? I had an old non-working one from a while back and there was a large glob of potting compound over some parts in the center of the board, so my guess is a micro-controller is involved. I would like to see about using a Propeller to make one if I could just figure out the circuit design.
http://www.esdjournal.com/techpapr/eosesd/grounds/fsg.htm
Found that information here: http://www.transforming-technologies.com/constant-monitors.html
(I'm not affiliated with Transforming Technologies
I'm gonna guess there are some form of voltage comparators that look at the difference in potential between the ground plug, person, and work surface. Of course if the unit is not connected to a viable 'ground', efficiency is reduced. And boy do they squeal when an open path is detected!!!
They actually work and they are an extra level of protection for those handling ICs at a bench.
DJ
DJ
http://www.element-14.com/community/docs/DOC-26779/l/arduino-emf-detector
