Filtering PWM/BAM Noise
I'm currently hearing PWM/BAM noise in an audio signal when ramping up/down the brightness of an LED. I'm new to signal processing (as well as electronics), and wanted to poll the experts here on the most effective solution.
Most of these are very basic questions, but I want to solidify my assumptions before I waste anymore of mine or anyone else's time.
1) Is this noise merely a result of the switching required to generate the PWM/BAM signal?
2) Would the cog/pin (C5/P7) relationship of my DAC/signal output enhance/suppress the noise?
3) Is a low-pass filter the most effective approach to suppress noise of this nature?
4) What's the best way to filter in terms of preserving the upper frequency band of my audio, and doing so with a minimal part count and footprint (I have very limited board real estate to work with).
Audio Circuit Schematic:
Again, lots of new concepts here for me... I know I have lots of requisite knowledge to integrate, but am I on the right path to finding a solution? Any thoughts, questions, insights appreciated.
I appreciate everyone's time.
P7 --o---||-----GND ----||------------ 7.4V
| 10nF .1uF |
| ___ || .-----o----.
'--|___|------||----| TDA7052 |-------1W 8ohm SPK
4.7k 1uF
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
