Code blocks should use monospaced font
Snippet from http://forums.parallax.com/showthread.php?129168-Considering-the-release-a-Joystick-hack-Object&p=972304&viewfull=1#post972304:
In code, I expect columns of text to be visually aligned, but on my screen at least, the above code does not line up visually.
test temp, pinn13 wz '9
if_z or button, butt9
if_nz andn button, butt9
test temp, pinn14 wz '10
if_z or button, butt10
if_nz andn button, butt10
test temp, pinn12 wz '11
if_z or button, butt11
if_nz andn button, butt11
test temp, pinn11 wz '12
The columns are aligned on my screen (OS/X, Opera 10). Which OS and browser are you using? Can you post a screenshot? It might be a font issue. If your computer doesn't have any of the fixed-width fonts specified by the stylesheet, it may be substituting a proportionally-spaced font.
I see the problem. It is a monospaced font, but the space character is ever so slightly narrower than the other characters. I've seen this happen when boldface characters are displayed -- especially with fonts like the Parallax font, which doesn't come with its own boldface glyphs. But this is a first for normal characters.
That typeface looks like Consolas. Try this: When in Opera, type Alt-P to bring up the Options panel, then select Advanced->Fonts. Under font-family Monospaced, if Consolas is displayed, change it to Courier New.
This is, admittedly, a shot in the dark. When I changed my default from Courier New to Consolas, the columns still lined up okay.
I guess it's a problem with this version of Opera.
