cognew and vga output question
Hi,
Here is my code, see below, sorry i dont know how to upload this as code, so i pasted it in, new to the propeller here. This is the problem.
I wrote two routines called updatevga and updatevga1, both operate on seperate variables, i and j.
If i run these, individually, or in the first loaded cog, without cognew, the program works fine. Individually they work in cognew also. But if I try to run these two in two different cogs, I get a mess on the screen. Both are accessing the same vga device. What I want to do is to update the screen at two different locations from two different Cogs. Is this possible or should I just have one cog do the screen updates. Seems to be getting out of wack results on the screen. This is part of a larger program that multiplexes multiple serial data sources in, so i just got it down to the root of this problem. Any suggestions or help would be great.
Walt,
''* VGA Text Multi Question Program *
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long i
long j
long stack[200]
long stack1[200]
OBJ
text : "vga_text"
Pub start
i:=10
j:=10000
'start term
text.start(16)
text.str(string(13,"MR BIGGS IS A CAT",13,"TEST message to VGA .. ",13,13,$C,5))
cognew(updatevga,@stack) ' comment this line out
cognew(updatevga1,@stack1) ' or comment this line out
pub updatevga
repeat
text.str(string($A,12,$B,14))
text.hex(i++, 8)
pub updatevga1
repeat
text.str(string($A,12,$B,12))
text.hex(j++, 8)
│ TERMS OF USE: MIT License │
│Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │
│files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │
│modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│
│is furnished to do so, subject to the following conditions: │
│The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│
│THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │
│WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │
│COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │
│ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │
Walt,
CON
VAR
long i
long j
long stack[200]
long stack1[200]
OBJ
text : "vga_text"
Pub start
i:=10
j:=10000
'start term
text.start(16)
pub updatevga
repeat
text.hex(i++, 8)
pub updatevga1
repeat
text.hex(j++, 8)
Also, code should be posted within [noparse] [/noparse] tags.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long i long j long stack[200] long stack1[200] [COLOR="red"]long lock[/COLOR] OBJ text : "vga_text" Pub start i:=10 j:=10000 'start term text.start(16) text.str(string(13,"MR BIGGS IS A CAT",13,"TEST message to VGA .. ",13,13,$C,5)) [COLOR="red"]lock := locknew[/COLOR] cognew(updatevga,@stack) ' comment this line out cognew(updatevga1,@stack1) ' or comment this line out pub updatevga repeat [COLOR="red"]repeat while lockset(lock)[/COLOR] text.str(string($A,12,$B,14)) text.hex(i++, 8) [COLOR="red"]lockclr(lock)[/COLOR] pub updatevga1 repeat [COLOR="red"]repeat while lockset(lock)[/COLOR] text.str(string($A,12,$B,12)) text.hex(j++, 8) [COLOR="red"]lockclr(lock) [/COLOR] DATlock = locknew
I changed the line above to be lock := locknew , which let it run as expected. Thank you.
Walt,
It works pretty good. The vga screen is just a cheap 19 inch Insigna flatscreen TV with a vga cable. Much easier than any LCD display and you can just plug it right into the Demo board. This is amazing for putting outputs out for debugging.
Anyways, i modified the program to see how this would work, and got a slightly different issue. Just trying to understand exactly what is going on here. So i put in a difference between the i and j which are being incremented in each seperate cog. The code is identical from that i can tell, other than a couple of different positions on the screen. But the difference between i and j will tend to change, and drift up. What started out as a difference of 9999 between the two starting values, is growing, and after a few minutes, it ends up as high as 10250... and changing a few minutes later it was at 10140. Sometimes it drifts downwards. Is this a sampling issue with the cogs spining around, who ever gets to the lock, can end up with it twice in a row, sometimes? There must be some slight difference in the processing time in the two routines when they are down in their subroutines.. Likely due to the jmps with different branch timing. I am guessing here. But maybe someone can explain this.
Thank You,
Walt,
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long i long j long k long stack[200] long stack1[200] long lock OBJ text : "vga_text" Pub start i:=1 j:=10000 k:=00 'start term text.start(16) text.str(string(13,"MR BIGGS IS A CAT",13,"TEST message to VGA .. ",13,13,$C,5)) lock:= locknew cognew(updatevga,@stack) ' comment this line out cognew(updatevga1,@stack1) ' or comment this line out pub updatevga repeat repeat while lockset(lock) text.str(string($A,12,$B,14)) text.hex(i++, 8) text.str(string($A,12,$B,10)) k:=j-i text.dec(k) lockclr(lock) pub updatevga1 repeat repeat while lockset(lock) text.str(string($A,12,$B,12)) text.hex(j++, 8) text.str(string($A,12,$B,8)) k:=j-i text.dec(k) lockclr(lock) DATThanks,
Walt,
