This is embarrassing
Hello,
I am working through a book on spin programming and this bug popped up,.
"ERROR: Expected an instructio or variable"
In this section that reads:
pub Go
dira [output_pin]~~ ' set pin to output
outa [output_pin]~ ' make pin low output
dira [input_pin]~ ' set pin to input
repeat
if ina[input_pin]==0 ' check pin for high or low
turnOn_LED ' method call
else
turnOff_LED ' method call
It tells me the line " turnOn_LED" has the error
I typed it exactly as in book, can someone explain what is wrong?
it wont let me archive it.
thanks,
wirecutter
pub Go
repeat
else
thanks,
wirecutter
Here is the full code.
{{ 12 sep 09 Harprit Sandhu
ButtonLED.spin
Propeller Tool 1.2.6
Chapter 15 program 1
Program turns on LED if input has been pulled up is grounded
con
_clkmode = xtal1 + pll2x ' system clock spec
_xinfreq = 5_000_000
input_pin = 23 ' input pin
output_pin = 27 ' output pin
inv_high = 0 ' invert high state
inv_low = 1 ' invert low state
pub Go
repeat
else
PRI turn_On_LED ' method to set the LED line high
outa[output_pin] :=inv_high ' sets the LED high
PRI turn_Off_LED ' method to set the LED line low
outa[output_pin] :=inv_high ' sets the LED low
The book is called "Programming the propeller with spin"
Tab book ISBN# 978-0-07-171666-6
wirecutter
repeat if ina[input_pin]==0 ' check pin for high or low turnOn_LED ' method call else turnOff_LED ' method call PRI turn[COLOR="red"]_[/COLOR]On_LED ' method to set the LED line high outa[output_pin] :=inv_high ' sets the LED high PRI turn[COLOR="red"]_[/COLOR]Off_LED ' method to set the LED line low outa[output_pin] :=inv_high ' sets the LED lowNote the different spelling between how the methods are called and how they are defined. Looks like lousy QA/QC if that's a straight copy from the book.thanks
wirecutter
