H bridge gone wild - Need a little help.
I am stumped on this h-bridge.
I apply the following truth table
0V at [ A ]
12V at [ B ]
5V at [ C ]
0V at [ D ]
Current flows at approximately 7amps but the Mosfet [ C ] begins to get very hot and very quickly. And as expected if I reverse the truth table Mosfet [ A ] gets very hot. Is there any thing you can bring to light any thing I am missing?
Thanks in advance
0V at [ A ]
12V at [ B ]
5V at [ C ]
0V at [ D ]
Thanks in advance
In that configuration, A should be getting hot. Notice I said that A should be getting hot, The drive strength that you have for your N-Mos transistors is adequate at 12V, but the drive strength that you have for your P-Mos transistors is only 5V... in order to match the P-Mos drive to the N-Mos drive you need to supply a -7V instead of 0V.
What's the voltage across the S/D of the N-Mos compared to the voltage across the S/D of the P-Mos ?
If turn on B and C at the same time they will short and burn up.
Same with A and D gated at the same time.
I cant imagine why any mosfet would be getting hot. Turning a mosfet completely on or completely off dissipates little to no heat (power) according to page 67 of the process and control book. You think I have not enough negative voltage on the Pmosfets?
** Edited - I did take out half of the bridge and it works flawlessly, so negative voltage cant be the issue can it?
The FETs that are conducting may not be fully on.
"I cant imagine why any mosfet would be getting hot. Turning a mosfet completely on or completely off dissipates little to no heat (power)" ... absolutely right, but your P-Mos transistors aren't saturated at the current you are trying to demand of them....
Your driving the N-Mos transistors with a voltage potential between the Source and Gate of 12V, that's perfect. However your driving the P-Mos transistors with only a 5 V potential across the Source and Gate. <-- This is your weak link. Since your supply to the H-Bridge is only 5V, you need -7 Volts to come up with the same amount of drive across the P-Mos (Gate and Source) to create a total voltage potential of 12V.
Measure the voltage across the Source and Drain, and I'll bet you find that you have quite a bit of loss across the P-Mos transistors.
