Propeller Sequencer Help — Parallax Forums
CaliforniaKidsCaliforniaKids Posts: 2
edited 2011-01-25 16:02 in Propeller 1
I am trying to build a basic sequencer. I would like to ripple a high output through 20 output pins. The time duration could be about .5 seconds dwell at each pin before moving on. It could loop forever. It would start when it received an input trigger and stop when it received a pulse on another input pin. I would like to remotely control it from about 50 feet away: Ethernet, USB I2C, RS 232, wireless? Any suggestions?
Thanks, CK
  • groggorygroggory Posts: 205
    edited 2011-01-25 11:33
    For the sequencing stuff, that could be done within your first attempt at the prop education kit. Piece of cake. Single cog in a loop doing the sequencing
    For the remote control you could do it with Xbee using the I/O pins (through the obex xbee object). ~$20/xbee
    or you could go simpler and cheaper and use something from linx wireless. LC series transmitter & receiver. Then throw on a 'splatch' antenna or 1/4 wave whip or JJB antenna. ~<$4/ radio + <$3/ antenna
    or http://www.sparkfun.com/products/691
  • JonnyMacJonnyMac Posts: 9,695
    edited 2011-01-25 13:01
    This is very easy -- the code below will give you an idea of starting and stopping a sequencer cog. The cog also monitors a global variable called hold so that you can hold and resume the sequence if desired.
    This is NOT a full program, just demo code to help you get up and running
    pub startseq
      hold := false
      cog := cognew(sequencer, @stack)
    pub stopseq
      if cog
        hold := true
        cogstop(cog~ - 1)
    pub holdseq
      hold := true
    pub resumeseq
      hold := false
    pri sequencer | t, idx
      t := cnt                                                      ' sync timing
      repeat
        repeat idx from 0 to 19                                     ' loop through pins
          outa[19..0] := 0                                          ' clear last
          repeat while (hold == true)                               ' if in hold mode
            t := cnt                                                '   resync timing
          outa[idx] := 1                                            ' output/high
          dira[idx] := 1
          waitcnt(t += clkfreq/2)                                   ' wait 1/2 second
    edited 2011-01-25 13:13
    JonnyMac wrote: »
    pub startseq
      hold := false
    pub stopseq
      if cog
        hold := true
        cogstop(cog~ - 1)
    pub holdseq
      hold := true
    pub resumeseq
      hold := false
      repeat
          dira[idx] := 1
    Also, if you need some precision note that flipping a pin high or taking it low takes about 6 microseconds when you're running the prop at 80 MHz (according to my logic analyzer)
    edited 2011-01-25 13:27
    ...was a clue that this could be handled in Spin. It would be nearly as easy in PASM, though.
    edited 2011-01-25 13:45
    JonnyMac wrote: »
    Wow, talk about an easy app.
    Might as well just run the prop at 20kHz off the internal oscillator and save some batteries too. :-)
    edited 2011-01-25 14:04
    If he uses contact closure inputs, absolutely.
    You could also use a set of serial latches which would require 3 pins (clock, data, reset) plus of course power/gnd. For 50ft, it really depends on what the environment is like - you may require rs232 or rs422/485 or straight prop to latches may work.
    So, it really depends on your app. The pasm code to run this is extremely simple.
