Ir module
I have a cybot Line follower board. http://www.lpilsley.co.uk/cybot/follower.htm is the link to the circuit diagram of the board. My question is can i connect this directly to the basic stamp 2 or no? Also if i can, can someone help me with the code?
I was looking at the Line Follower Board schematic. It will work with the Basic Stamps with no problems as long as, the schematic is the same as the board.
For the code side, I would suggest you to look at the Parallax site and you should find the code example for a Line Follower.
This should get you started going in the right direction.
