Amplifier for 5 MHz
I need to generate a 5 MHz preferably sinusoidal signal. I wanted to use a MOSFET (IRF7104 for example) and a small transformer (isolated output). The MOSFET would be driven with a 5 MHz square wave and then a small low pass filter. While this works, it produces very little power. I'd need to supply some mA at the output to a capacitive load (~500 pF). I think that those MOSFETs are a bit slow but it works. Has someone an idea of an alternative output stage I can use ? (I can also get a 5 MHz sinusoid, albeit very low power as input for this stage).
I tried to find a MOSFET driver suitable for this frequency, but they top at 1 MHz... any ideas ?
Thanks !
Thanks !
As Phil suggests, a very nice sinusoid is obtained by passing the transistor or IC output through a 5th-order LC filter made from common and inexpensive components. If you're interested in this, I'd be happy to recommend appropriate capacitor and inductor values.
