Powering BS1 USB without USB Connection?
Bill Chennault
All--
Is it possible to power the BS1 USB without a USB connection? +5vdc on VDD and -5VDC on VSS?
Thanks!
--Bill
Thanks!
--Bill
You might have problems with the +5V feeding back into the FT232R USB to Serial adapter chip. I know on the Prop that can cause problems with Reset, but, on the BS2, the Reset line is usually capacitively coupled which avoids the problem. I haven't seen a schematic for the BS1USB, so I can't tell for sure.
EDIT: Changed Vcc to Vdd.
--Bill
1) Where would you put it and how would you connect it? The BS1USB board is very crowded and very small
2) A diode has a drop across it of around 0.6V. In a 5V circuit, that would drop the voltage to 4.3V. USB doesn't always supply 5V, so the voltage available to the BS1 might often be less than 4.3 which would cause the BS1 to reset.
http://www.bixnet.com/miusbpoacwac.html
http://www.bixnet.com/3usbcachfori.html
