Circuit bending the Kaossilator?
Greetings,
I'm interested in hijacking the system clock in the Korg Kaossillator Dynamic Phrase synthesizer. Getlofi.com offers the LTC 1799 Precision Clock Kit -$15 USD LTC 1799 Kit LTC Module, 250K Potentiometer, Kynar Wire, Knob, Switch, Trim Resistors, for $15.
But this seems too hard to control in a musical instrument, so I would like to use a Prop to generate the 1 to 33 MHz signal required. Perhaps it could be useful as a sequencer. Can the Prop generate this signal and vary it rapidly? What would the minimum settling time of the PLL look like? How do I buffer the 33 MHz Prop signal to interface with a 4.5 Volt system?
Thank you for any and all ideas. This concept could be useful for other "circuit bent" musical devices...
