Ram Test for C3 — Parallax Forums
Ram Test for C3
RossHRossH Posts: 5,643
edited 2011-01-21 08:21 in Propeller 1
Hi,
Can someone with a C3 please try the enclosed binary and see if it works? - it's a simple RAM test for testing Catalina's 64kb SPI SRAM access code.
The program uses the serial port, and can be loaded by any suitable means (including the Parallax Propeller Tool or Catalina Payload).
When run, it prints Start? and waits for a y (this gives you time to start a serial terminal emulator). The first test is a trivial test which can be repeated by pressing y again. Or press n to go to the more complex test (which usually prints nothing).
If everything works ok, you should see something like:
START?y
A 00000000 00000000 DEADBEEF
A 00000004 00000004 DEADBEEF
A 00000008 00000008 DEADBEEF
A 0000000C 0000000C DEADBEEF
A 00000010 00000010 DEADBEEF
A 00000014 00000014 DEADBEEF
A 00000018 00000018 DEADBEEF
A 0000001C 0000001C DEADBEEF
A 00000020 00000020 DEADBEEF
A 00000024 00000024 DEADBEEF
A 00000028 00000028 DEADBEEF
A 0000002C 0000002C DEADBEEF
A 00000030 00000030 DEADBEEF
A 00000034 00000034 DEADBEEF
A 00000038 00000038 DEADBEEF
A 0000003C 0000003C DEADBEEF
AGAIN?n
DONE
AGAIN?
Here is my XMM RAM access logic, in case anyone wants to check it:
'------------------------- C3 SPI XMM Support Routines -------------------------
' XMM_Activate : Activate the XMM bus.
XMM_Activate
              muxc    XMM_Flags,#1              ' save C flag
              muxnz   XMM_Flags,#2              ' save Z flag
              andn    dira,MASK                 ' set I/O pins as inputs while initializing
              andn    outa,MASK                 ' set all I/O pins zero ...
              or      outa,CS_BOTH              ' ... except CS_CLR and CL_CLK
              or      dira,DIRN                 ' set pin directions
              mov     XMM_Addr,BIT15            ' select ...
              call    #XMM_BankSelect           ' ... SPI SRAM bank 1
              mov     outx,#%0000_0001          ' set ...
              call    #XMM_OutByte              ' ... selected SPI SRAM ...
              mov     outx,#%0100_0000          ' ... to sequential ...
              call    #XMM_OutByte              ' ... mode
              mov     XMM_Addr,#0               ' select ...
              call    #XMM_BankSelect           ' ... SPI SRAM bank 0
              shr     XMM_Flags,#1 wz,wc        ' restore C & Z flags, fall through to ...
'XMM_Tristate : Give up the XMM bus. Call this to allow other cogs to use microSD etc.
'               To activate XMM again, call XMM_Activate.
XMM_Tristate
              andn    outa,CS_CLR               ' Reset SPI channel ...
              or      outa,CS_CLR               ' ... to deselect SPI SRAMs
XMM_Activate_ret
XMM_Tristate_ret
              ret
#ifdef NEED_XMM_READLONG
' XMM_ReadLong : Read long from XMM at address in XMM_Addr into the destination register
'                set up in XMM_Dest. XMM_Activate should be called at least once before
'                this routine is used.
' On entry:
'    XMM_Addr : address to read (up to 16 bits)
'    XMM_Dst  : destination of this instruction set to destination register
' On exit:
'    Destination register contains long read from XMM.
' XMM_ReadMult : Read multiple bytes in source register to XMM at address XMM_Addr.
'                XMM_Activate should be called at least once before this routine is used.
' On entry:
'    XMM_Len  : number of bytes to read (usually 1, 2 or 4)
' On exit:
'    Destination register contains bytes read from XMM.
XMM_ReadLong
              mov     XMM_Len,#4                ' read 4 bytes
XMM_ReadMult
              mov     outx,#%0000_0011          ' Set Command ...
              call    #XMM_SetCmdAddr           ' ... and Address (and lower CS)
              add     XMM_Addr,XMM_Len          ' update XMM_Addr
              mov     XMM_Temp,#0
:ReadLoop
              call    #XMM_InByte               ' read next byte from SPI
              and     outx,#$FF
              or      XMM_Temp,outx
              ror     XMM_Temp,#8
              djnz    XMM_Len,#:ReadLoop        ' repeat while XMM_len <> 0
XMM_Dst       mov     0-0,XMM_Temp              ' save the result
              andn    outa,CS_CLR               ' reset SPI Channel ...
              or      outa,CS_CLR               ' ... to terminate read
XMM_ReadLong_ret
XMM_ReadMult_ret
              ret
#endif
#ifdef NEED_XMM_WRITELONG
' XMM_WriteLong : Write long in source register to XMM at address XMM_Addr.
' On entry:
'    XMM_Addr : (32-bit) address to write (up to 16 bits)
'    XMM_Src  : source of this instruction set to source register
' On exit:
'    XMM_Addr incremented by 4.
' XMM_WriteMult : Write multiple bytes in source register to XMM at address XMM_Addr.
' On entry:
'    XMM_Addr : address to write (up to 16 bits)
'    XMM_Len  : number of bytes to write (usually 1, 2 or 4)
' On exit:
XMM_WriteLong
              mov     XMM_Len,#4                ' write 4 bytes
XMM_WriteMult
              mov     outx,#%0000_0010          ' Set Command ...
XMM_Src       mov     XMM_Temp,0-0              ' save the value to write
:WriteLoop
              mov     outx,XMM_Temp
              and     outx,#$FF
              call    #XMM_OutByte              ' write a byte to SPI
              ror     XMM_Temp,#8               ' shift next byte down to prepare
              djnz    XMM_Len,#:WriteLoop       ' repeat while XMM_len <> 0
XMM_WriteLong_ret
XMM_WriteMult_ret
              ret
#endif
#ifdef NEED_XMM_WRITEPAGE
' XMM_WritePage : Write bytes from Hub RAM to XMM RAM
' On entry:
'    XMM_Addr  (32-bit): destination address in sram, 16-bits used
'    Hub_Addr  (32-bit): source address in main memory, 16-bits used
'    XMM_Len   (32-bit): number of bytes to write.
XMM_WritePage
:WriteLoop
              rdbyte  outx,Hub_Addr             ' get byte from source (Hub)
              call    #XMM_OutByte              ' write byte to SPI
              add     Hub_Addr,#1               ' inc source address
              add     XMM_Addr,#1               ' inc dest address
XMM_WritePage_ret
              ret
#endif
#ifdef NEED_XMM_READPAGE
' XMM_ReadPage : Read bytes from XMM RAM to Hub RAM.
' On Entry:
'    XMM_Addr  (32-bit): source address in sram, 16-bits used
'    Hub_Addr  (32-bit): destination address in main memory, 16-bits used
'    XMM_Len   (32-bit): number of bytes to read.
XMM_ReadPage
:ReadLoop
              call    #XMM_InByte               ' read byte from SPI
              wrbyte  outx,Hub_Addr             ' write byte to destination (Hub)
              add     Hub_Addr,#1               ' inc dest address
              add     XMM_Addr,#1               ' inc src address
XMM_ReadPage_ret
              ret
#endif
'XMM_SetCmdAddr : Set XMM command and address (and lower CS). XMM_Activate should be called
'                 at least once before this routine is used.
'On Entry:
'   outx     : Command (2 for read, 3 for write)
'   XMM_Addr : address to set (up to 16 bits)
'On Exit:
'   XMM_Addr : preserved
'   C & Z flags destroyed!
XMM_SetCmdAddr
              call      #XMM_BankSelect         ' select the SPI SRAM bank
              mov       XMM_Test,#8             ' command is 8 bits
              rol       outx,#24                ' put first bit in MSB
:CmdLoop
              rol       outx,#1 wc
              muxc      outa,IBIT
              or        outa,CLCK
              andn      outa,CLCK
              djnz      XMM_Test,#:CmdLoop
              mov       XMM_Test,#16            ' 16 address bits
              rol       XMM_Addr,#16            ' put first address bit in MSB
:AddrLoop
              rol       XMM_Addr,#1 wc
              muxc      outa,IBIT
              or        outa,CLCK
              andn      outa,CLCK
              djnz      XMM_Test,#:AddrLoop
XMM_SetCmdAddr_ret
              ret
' XMM_OutByte - send a byte to the SPI RAM
' On entry: byte in outx (lower 8 bits)
' On exit: C flag destroyed!
XMM_OutByte
              mov       XMM_Test,#8             ' 8 bits
:OutLoop
              rol       outx,#1 wc
              muxc      outa,IBIT
              or        outa,CLCK
              andn      outa,CLCK
              djnz      XMM_Test,#:OutLoop
XMM_OutByte_ret
              ret
' XMM_InByte - receive a byte from SPI RAM
' On exit: outx shifted left 8 bits, new byte in lower 8 bits
' On exit: Z flag destroyed!
XMM_InByte
:InLoop
              test      OBIT,ina wz
              shl       outx,#1
              muxnz     outx,#1
              or        outa,CLCK
              andn      outa,CLCK
              djnz      XMM_Test,#:InLoop
XMM_InByte_ret
              ret
' XMM_BankSelect - select appropriate SPI SRAM bank based on address
' On entry: XMM_Addr bit 15 determines SRAM bank to select (0 or 1)
XMM_BankSelect
             andn       outa,CS_CLR             ' Reset SPI Channel ...
             andn       outa,CS_CLK             ' toggle SPI Select Clock ...
             or         outa,CS_CLK             ' ... to select first SRAM (bank 0)
             test       XMM_Addr,BIT15 wz       ' if bit 15 set ...
       if_nz andn       outa,CS_CLK             ' ... toggle SPI Select Clock ...
       if_nz or         outa,CS_CLK             ' ... to select second SRAM (bank 1)
XMM_BankSelect_ret
             ret
' XMM variables
outx          long      $0
XMM_Flags     long      $0
XMM_Len       long      $0
XMM_Temp      long      $0
XMM_Test      long      $0
XMM_Addr      long      $0
HUB_Addr      long      $0
' C3 Hardware Access:
MASK          long      (|<Common#SPI_CS_CLK) | (|<Common#SPI_CS_CLR) | (|<Common#SPI_CLK) | (|<Common#SPI_SI) | (|<Common#SPI_SO)
DIRN          long      (|<Common#SPI_CS_CLK) | (|<Common#SPI_CS_CLR) | (|<Common#SPI_CLK) | (|<Common#SPI_SI)
CS_CLK        long      (|<Common#SPI_CS_CLK)
CS_CLR        long      (|<Common#SPI_CS_CLR)
CS_BOTH       long      (|<Common#SPI_CS_CLK) | (|<Common#SPI_CS_CLR)
OBIT          long      (|<Common#SPI_SO)
IBIT          long      (|<Common#SPI_SI)
CLCK          long      (|<Common#SPI_CLK)
BIT15         long      $8000
'---------------------- End of C3 SPI XMM Support Routines ---------------------
Ross.
    edited 2011-01-16 06:10
    Hi Ross,
    I tried this on my prototype C3 and unfortunately it doesn't seem to work. Here is some of the transcript from my serial terminal (bst). I deleted a lot of blank lines to save space.
    START?y
    A 00000000 00000000 00000000
    A 00000004 00000000 00000000
    A 00000008 00000000 00000000
    A 0000000C 00000000 00000000
    A 00000010 00000000 00000000
    A 00000014 00000000 00000000
    A 00000018 00000000 00000000
    A 0000001C 00000000 00000000
    A 00000020 00000000 00000000
    A 00000024 00000000 00000000
    A 00000028 00000000 00000000
    A 0000002C 00000000 00000000
    A 00000030 00000000 00000000
    A 00000034 00000000 00000000
    A 00000038 00000000 00000000
    A 0000003C 00000000 00000000
    AGAIN?n
    FAIL 00000000=00000000(00004000)
    FAIL 00000004=00000000(00003FFF)
    FAIL 00000008=00000000(00003FFE)
    FAIL 0000000C=00000000(00003FFD)
    FAIL 00000010=00000000(00003FFC)
    FAIL 00000014=00000000(00003FFB)
    FAIL 00000018=00000000(00003FFA)
    FAIL 0000001C=00000000(00003FF9)
    FAIL 00000020=00000000(00003FF8)
    FAIL 00000024=00000000(00003FF7)
    FAIL 00000028=00000000(00003FF6)
    FAIL 0000002C=00000000(00003FF5)
    FAIL 00000030=00000000(00003FF4)
    FAIL 00000034=00000000(00003FF3)
    FAIL 00000038=00000000(00003FF2)
    FAIL 0000003C=00000000(00003FF1)
    FAIL 00000040=00000000(00003FF0)
    FAIL 00000044=00000000(00003FEF)
    FAIL 00000048=00000000(00003FEE)
    FAIL 0000004C=00000000(00003FED)
    FAIL 00000050=00000000(00003FEC)
    FAIL 00000054=00000000(00003FEB)
    FAIL 00000058=00000000(00003FEA)
    I've also attached the cache driver I use with ZOG on the C3. It has the same interface as jazzed's SDRAM cache driver.
    David
  • AndreLAndreL Posts: 1,004
    edited 2011-01-16 12:43
    @Rossh, do you have a C3 yet? Or not yet, and just trying to test code on someone elses, so you you can work until you get one?
    Andre'
  • RossHRossH Posts: 5,643
    edited 2011-01-16 14:02
    Hi Andre,
    No, I haven't ordered a C3 yet - Parallax's shipping costs doubles the price of the board, so I thought I'd wait until I could investigate alternative methods of acquiring one.
    Hi David,
    Thanks, I'll check my code (and compare it with yours) and re-post an amended version.
    Ross.
    edited 2011-01-19 01:57
    Hi David,
    Aha! For a start, it seems I had my CLR and INC pins for selecting the SPI channel the wrong way round! If you get a chance, try the attached executable. But don't worry too much - my own C3 should arrive in a few days, so I'll fix it then.
    Ross.
    edited 2011-01-19 04:03
    RossH wrote: »
    Hi David,
    Ross.
    Looks much better this time. I think it's working. Congratulations!
    START?y
    AGAIN?n
    DONE
    AGAIN?
    edited 2011-01-19 14:04
    Hi David,
    Thanks! Yes, that's working. This means I can now execute C programs out of the 64Kb of SPI SRAM on the C3 (albeit a bit slowly!). Adding in the FLASH support should be easy. I'll do that over the next week or so, so by the time my C3 arrives, Catalina should be fully functional.
    I'll also have a look at using your caching driver. It will be interesting to see the performance difference.
    Ross.
    edited 2011-01-19 14:40
    I'm not sure how fast my cache code is but it certainly is nice to have the 1mb flash chip for code. 1mb of code and 64k of data makes a pretty usable environment for C programs. My simple basic bytecode compiler runs on the C3 comfortably where it was very tight with only 64k for both code and data and didn't fit in 32k of hub memory at all. What is involved with adding a new memory system to Catalina? I have been meaning to try it myself.
  • Ken GraceyKen Gracey Posts: 7,418
    edited 2011-01-19 15:14
    RossH, you should be able to process an order for USPS Priority Intl for a low cost, like $10-20. I'll get our Sales Manager to review the problem and contact you. Maybe we can mimic the sales order entry problem that's throwing an error in our system.
    One alternative is to enter the order with whatever shipping method you want and put in the notes "Please use the cheapest USPS method and credit me the difference charged by the on-line order system". - Ken
  • jazzedjazzed Posts: 11,803
    edited 2011-01-19 15:35
    RossH wrote: »
    It will be faster even though the backstore choices (some SPI device) are slow. Of course the same interface is also used by the SDRAM cache driver which makes things interesting. The performance is different of course between SPI RAM and SDRAM. I'm looking into to doing a C3 8MB SDRAM add on module which at first glance seems possible..
    edited 2011-01-19 16:06
    Ken Gracey wrote: »
    Hi Ken. The UPS cost quoted by your online ordering system was US$65, so I opted for USPS instead (~US$38 from memory). I still thought was a bit steep considering USPS themselves only charge US$13 (I checked) - but I paid it, and as far as I know the order has been processed - certainly it has already been debited from my credit card.
    Happy to get a credit if you can figure out a cheaper way to post it.
    Ross.
    edited 2011-01-19 16:13
    David Betz wrote: »
    Hi David,
    The code I posted above is all that is required (the error was in the pin definitions, not in that code). This is the actual code I include in the XMM kernel. Of course, this is a pretty brain-dead implementation for a serial interface - it is cribbed from my parallel SRAM code. For serial SRAM it will be at least 10 times slower - but I expect a cache will speed things up quite a bit. Of course, the overhead of interacting with the cache (which will be in another cog) will slow it back down again, but you should still see better performance (at the cost of a cog).
    I will also have to add a new option to the C3 target to tell it to put read/write segments in the SPI SRAM and read-only segments in the SPI FLASH, but that's fairly simple.
    Ross.
    edited 2011-01-19 16:14
    jazzed wrote: »
    Now THAT would be nice!
    Ross.
  • Jim CareyJim Carey Posts: 15
    RossH wrote: »
    Ross.
    Hi Ross,
    Looks like the US Postal Service changed the link for 1st class international. Our IT manager is working on getting the correct link. We are dealing with the US post office, so it could take a bit to get this fixed. For now, customers can put a note in the comments section of the order to ship 1st class international, or call our sales department and place an order.
    Sorry for the trouble and we hope to have this fixed soon.
    Jim Carey
    Parallax Sales
