Genius Needed! — Parallax Forums
Genius Needed!
idbruceidbruce Posts: 6,197
edited 2011-01-12 21:53 in Propeller 1
llllllllllllllllllllllllllllll
    edited 2011-01-11 19:48
    Bruce,
    From my looking at it, I agree things don't seem to add up.
    Debugging suggestion..
    Ad the pst (parallax serial terminal object) and see what FirstDigitMonth actually looks like with a
    pst.dec(FirstDigitMonth)
    pst.newline
    between your input and if statement.
    OBC
    edited 2011-01-11 19:53
    You should use IF FirstDigitMonth <> 13 AND FirstDigitMonth <> 0
  • idbruceidbruce Posts: 6,197
    Oldbitcollector
    I wish I could, but the prop and keypad are mounted on my machine and away from the computer. I am doing uploads with a portable device using PropellerLoader.
    Bruce
    I think you want AND not OR. You only want to execute the body of the IF if FirstDigitMonth is neither 13 nor 0. In fact, your IF statement is always true since any value is either not 13 or not 0.
  • RossHRossH Posts: 5,639
    edited 2011-01-11 19:55
    The expression "FirstDigitMonth <> 13 OR FirstDigitMonth <> 0" evaluates to true for any given number.
    Ross.
    EDIT: David, you beat me to it!
    edited 2011-01-11 19:58
    Thanks everyone for all the replies
    Okay I agree it should be an AND. My Bad.
    Bruce
    PS I will be back if that does not fix it :)
    edited 2011-01-11 20:02
    Nice Didn't see that here... Would have driven me bat-nuts too. :)
    Good group of logic thinkers here.
    OBC
    edited 2011-01-11 20:04
    Good Job Guys
    Thank you VERY much. That one would have had me going for a little while.
    Bruce
  • lardomlardom Posts: 1,659
    edited 2011-01-12 17:37
    OBC, Orrville. Sorry, I couldn't resist.
    :) Yep My bad
