How precise is the S2's drawing?
Oldbitcollector (Jeff)
Ok, so I've seen some of the video showing the S2 drawing words.. Pretty cool stuff.
I'm curious.
Could the S2 be used to draw cut marks on a sheet of material and get it reasonably precise?
I can see the S2 being used as a tool for making other projects.
OBC
I'm curious.
OBC
With calibration - it is pretty accurate. Also - there is amazing repeatability between different S2s using the same code. For example, I sent some code to Phil Pilgrim and his S2 responed the same as mine. It let him help me correct some things that were not working in my code as regards calibration.
I say give it a try!
Rich H
The wheels on S2s have a fair amount of play in them. Wiggle them sideways and you can see. That will add some error that will accumulate in a complex series of maneuvers such as yours. I took the same slop out of my S1 by carefully filling the gaps between the gearmotor shaft and wheel hub adapter with gap-filling superglue. It takes patience, you have to keep testing it to make sure it runs true as you sneak up on the final position. That's on my to do list for my S2.
Once you've found calibration values that work for a particular bot on a particular surface, you can save them using the write_wheel_calibration method.
Thanks! One of the students in the robotics club provided me with a spreadsheet of all the coordinates and radiuses. I scaled them and entered each manually. I have the feeling that fixing the play, the variable distance between the points of contact, and setting the exact Wheel_space and Full_circle values will make a remarkable improvement in accuracy.
Rich H
