[New Test] AJAX, LED, IP Cam and Spinneret
Please give this a shot. The URLs are in the Spinneret forum.
http://forums.parallax.com/showthread.php?128600-AJAX-Spinneret-LED-Demo-and-IP-Camera
[Old Stuff but still works]
Title: Please stress test my Spinneret Web Server
Here's the URL... click away
http://spinneret.servebeer.com:5000/led.htm
Thanks for the help.
Feel kinda' dumb that I didn't do that in the first place.
POST /login.shp HTTP/1.1
User-Agent: Opera/9.80 (Macintosh; PPC Mac OS X; U; en) Presto/2.2.15 Version/10.10
Host: spinneret.servebeer.com:5000
Accept: text/html, application/xml;q=0.9, application/xhtml+xml, image/png, image/jpeg, image/gif, image/x-xbitmap, */*;q=0.1
Accept-Language: en,ja;q=0.9,fr;q=0.8,de;q=0.7,es;q=0.6,it;q=0.5,nl;q=0.4,sv;q=0.3,nb;q=0.2,da;q=0.1,fi;q=0.1,pt;q=0.1,ko;q=0.1
Accept-Charset: iso-8859-1, utf-8, utf-16, *;q=0.1
Accept-Encoding: deflate, gzip, x-gzip, identity, *;q=0
Referer: http://spinneret.servebeer.com:5000/login.shp
Connection: Keep-Alive, TE
TE: deflate, gzip, chunked, identity, trailers
Content-Length: 40
Content-Type: application/x-www-form-urlencoded
Ah, I didn't realize those were the live settings!
You should now have at least one IE header! :-)
Yes I see IE
@Phil, if you happen to see this, I think I solved the POST issue. I'm not sure though because I can't reproduce the problem so I just took a stab at it. If you could give POST another shot, I'd appreciate it.
I see the post. I bet it has something to do with return\line feed? I'll fix it when I get home from work.
Timeout Alert POST /login.shp HTTP/1.1 User-Agent: Opera/9.80 (Macintosh; PPC Mac OS X; U; en) Presto/2.2.15 Version/10.10 Host: spinneret.servebeer.com:5000 Accept: text/html, application/xml;q=0.9, application/xhtml+xml, image/png, image/jpeg, image/gif, image/x-xbitmap, */*;q=0.1 Accept-Language: en,ja;q=0.9,fr;q=0.8,de;q=0.7,es;q=0.6,it;q=0.5,nl;q=0.4,sv;q=0.3,nb;q=0.2,da;q=0.1,fi;q=0.1,pt;q=0.1,ko;q=0.1 Accept-Charset: iso-8859-1, utf-8, utf-16, *;q=0.1 Accept-Encoding: deflate, gzip, x-gzip, identity, *;q=0 Referer: http://spinneret.servebeer.com:5000/login.shp Connection: Keep-Alive, TE TE: deflate, gzip, chunked, identity, trailers Content-Length: 41 Content-Type: application/x-www-form-urlencoded
You could have at least mentioned that instead of "I think I crashed it."
@Bocephus, increased the URL stack to 512
homepage OK
sensordata two lines
cofiguration panel blinks OK NOK OK NOK
log shows up some plain text then
pageload error
best regards
Stefan
It's the HTML decode code, I never put that many spaces in the querystring. Back to the drawling board.
I just held the 'a' down for a random amount of time. Sorry Mike G, you are right, I should have been more informative.
I checked it just now but it doesn't show anything in the browser when I enter a variable. I won't overflow your stack anymore.
