Robot travel speed
This is kind of an odd-ball question but:
What travel speed would you recommend for a bot base? I plan to use it for obstacle avoidance, probably with the PING and/or IR, some decision making, maybe line following etc. Specs that might help:
I would like to keep the base at or under 16" x 16" and the entire bot under 10lbs.
I'd be using my BS2 for the time being.
Terrain is indoors, tile/carpet
I hope to use about a 3.5" wheel DIA for ground clearance on carpet (not that it matters)
I plan to use my four cell NiMh pack (hopefully)
I can work with inches per minute, inches per second, furlongs per hour, motor speed with a wheel diameter or whatever you have.
I'm using Parallax continuous rotation servos now with a ~2" wheel. It's underpowered and slow, won't run on carpet and is generally pretty pathetic. Gearhead motors are expensive so I'd like to purchase only one pair. From the speed, I'll determine torque requirements, etc.
I'd be more worried about torque than velocity. Get the highest torque for the money.... no less than 6rpm, 20rpm, 50rpm?
I'm glad you replied, I value your opinion. You seem to be experienced in the builds I described. I was looking in the 60rpm category. I suppose that WOULD be pretty fast once I consider it.
With a 4" wheel and:
6RPM = 6.3ft/min
20RPM = 20.9ft/min
50RPM = 52.4ft/min
10RPM = 10.5ft/min. I think I'm going to shoot for the 10-15ft/min area unless anyone wants to disagree. That should keep current relatively low and as a wild guess, give me time for processing.... I think. If I can find the right motor and torque, I may go as high as 20-25ft/min just to have the speed option. Brushed DC motors in my experience develop poor torque at less than 50% rated speed. I saw (on here) where someone claimed a PWM control using two 555 timers give them 100% torque WAY down low. Maybe I need to experiment first.
http://forums.parallax.com/showthread.php?126435-Motor-speed-control-with-PWMPAL&highlight=gearmotor
...and come to think of it, I'm pretty sure I have that Radio Shack book! I'll have to look.
and 46ozin seems like it would be enough to run slower. It's still 62RPM though a 297:1 gear. That baby must be humming! 18K rpm motor. Wow.
This could be the ticket though: http://www.bgmicro.com/MOT1011.aspx
edit: Maybe not. The motor looks like it pulls 800mA no load. That's a lot man.
Second motor looks like mine, BUT:
1) It has the GOOD strong wheels that you can't find anymore; new ones are black & thin plastic
2) these are used
3) motor must be different; lower voltage and higher current
