Propeller auto power-off circuit - help please!
I'm looking for a way to implement power management so that the propeller can turn off the power to a device (and itself), not just go into low-power mode.
My device will be using a 9v battery for power. In order to maximize the life of the battery, I would like to have a circuit that:
* Uses no (ideal) or very little power (ok) when off.
* Turns on when a button is pressed (this button is not connected to the propeller and serves only as a power on request)
* Stays on until turned off by the propeller sending an appropriate (low or high) signal via an I/O pin.
Thanks!
Walter Mosscrop
Thanks!
Walter Mosscrop
I have used some in the past and they solved this problem beautifully..
HTH
http://forums.parallax.com/showpost.php?p=730860&postcount=7
Mike & Miner_with_a_PIC - that's exactly what I was looking for... I had searched the forums but didn't find that post.
Thanks!
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1805,P131515
It's a low-frequency oscillator, and can be configured for a period of up to 9.5 hours! In the datasheet there's an example where it is used to wake up a microcontroller after a set interval. The microcontroller does its thing, then can send a signal to the timer to go into "reset" again until the next interval. It would be easy enough to add a button in there that acts as a manual "wake up" signal for the system.
(Memo to self: buy a good magnifying glass)
It was nice to be able to build something from less than $1 in parts (that I already had, a first!)
I just have two more questions:
It appears that the maximum current rating for a 2n3904 is 200mA, so the circuit (including the voltage regulators) will be limited to about 150mA continuous current in practice. Correct?
If so, what transistors could I use to safely support 300mA of continuous current? I'm not sure if I'll need that much current, but I'm driving a LCD w/LED backlights that uses 80mA by itself, along with the propeller, an IR LED, and several other LED's.
Thanks in advance!
Walter
I'm glad you got it working!! This is a pretty forgiving circuit, it's basically a gated SCR (Silicon Controlled Rectifier) ... in fact you could substitute one for the NPN and the PNP whose base-emitter junction has a 10k resistor across them. ... In this case you will need to rate both of those transistors in the 'SCR' to your particular LOAD demand. The real trick is in turning an SCR off once it has been turned on. Once they are turned on, they become VERY saturated. The NPN of the 'SCR' has a path to ground through the LM2940-5 voltage regulator creating a necessary voltage drop that helps to facilitate turning the SCR off. This drop in voltage allows the NPN connected to the I/O pin to 'crowbar' the ground across the B-E junction of the 'SCR's' NPN allowing it to turn completely off.
Last month, I was involved in a Timer project with an Atmega where I was faced with the same sort of problem. I wanted the system to be triggered with a mercury switch and to switch itself off at the end of the count down. I used a schematic with 2 transistors (see the first attached picture).
I understand that this schematic will not work with the Propeller if this one takes 1 or 2 seconds to start. So I am very interested in the schematic of Beau Schwabe but I am not an ingeneer and I don't quite understand how it works (see picture2) . (I added some identifications to transistors and resistors).
I see that when the switch is ON, the base of T1 is driven low, so T1 becomes passing, driving at the same time the base of T2 high. T2 continues to drive low the base of T1 so the system is latched, giving the power to the first voltage regulator. Here is my first difficulty : the power supply has to cross two parallel systems made of one transistor and one 10K resistor ==> not much will be able to pass through.
I have a second difficulty when one wants to cut off the system. I suppose it is obtained when the Prop is driving high the base of T3 through R4. Then the base of T2 becomes lower than its emitter ==> T2 is blocked ==> the base of T1 becomes high and T1 is blocked as well. My question is: when the base of T3 becomes high, there seems to be a short between the power supply and GND through T1 and T3 which could ruine these transistors.
You raise an interesting point: i.e. how much current is the circuit able to pass when it must all flow through two 10K resistors and/or two base-emitter junctions. IOW, there's no solid emitter-collector current path in the circuit. Moreover, your point about the dead short during turnoff is well taken. Perhaps Beau can fill us in.
Phil, in my application I need only about 150mA... which seems to be within the design limits of the transistors.
The turnoff pulse generated by the propeller (to create the dead short) is very short... a fraction of a second or so. I've used 1/8 second and it seems to work reliably.
However, I agree that shorting is normally not desirable.
Beau - would the addition of a resistor between the shutoff transistor's emitter and ground solve the issue? If so, what would be an appropriate value? I understand the basic workings of the circuit but the calculation of this value is beyond my limited mental facilities
10k C-E o--/\/\--o--->|---o | | T2 | | E-B | | +V ---o--->|---o | | T1 B-E | | o--->|---o---> To Regulator | | T2 | | | | | E-C | 10k | o--->|---o--/\/\--o T1
essentially 2 diodes in series, with two other series diodes in parallel, so you have 2-diode drops (about 1.2V)
"Beau - would the addition of a resistor between the shutoff transistor's emitter and ground solve the issue?" - probably not, SCR's latch hard and you need to crow-bar them to turn them off. The amount of time that the 'short' is introduced is very brief.
I guess the difficulty I have with the SCR "equivalent" circuit, is that, even though the B-E junctions are conducting, they're not typically rated for the kind of current the C-E pathway is designed to handle. IOW, given that a real SCR is a monolithic circuit with a clearly defined high-current pathway, is the "equivalent" circuit really an adequate real-world substitute? Or does it serve merely as a pedagogical example for engineering students?
"...even though the B-E junctions are conducting, they're not typically rated for the kind of current the C-E pathway is designed to handle." - Correct, but for the 2n3904 and the 2n3906, the maximum base current is rated at 100mA ... Essentially you have two B-E paths in parallel, so this being the 'weakest link' with the SCR arrangement, you should be able to drive 200mA.
2n3904 Datasheet reference
2n3906 Datasheet reference
It is much clearer for me now.
And thank you to everyone from me too. I have learned quite a bit from this deceptively simple exercise--and have a working circuit to boot!
Walter
The nice thing about that is that there is no need for a signal connection back to turn off the SCR. It is an issue of the ratio of operating current to sleep current. In the case of the Prop, it could drop back to RCslow and that would end up in it being completely turned off. There are nice SCRs in TO92 packages that can easily handle 150 mA.
I've heard a rule of thumb that the base current for a transistor should be limited to 1/3 of the rated average collector current, or 1/10 for a Darlington or superbeta transistor.
@Tracy Allen: Beau's circuit could emulate that function fairly easily using 2K ohm resistors in place of the 10K resistors and switching the voltage regulators to low quiescent current devices. (any of Microchip's MCP170x series would work well with <2uA quiescent current)
Lawson
