Dynamic Spinneret with HttpRequest Object and EEPROM Configuration Page
                    Here's my latest Spinneret Web Server source. I added a configuration page that reads setting from EEPROM.  I'll leave the server up for a few hours today if anyone wants to check it out.
http://spinneret.servebeer.com:5000/
Plus I attached the source files. Just go to the configuration link from the home page.
I'm thinking of moving the configuration page to EEPROM. Right now it's just a bunch of string writes in a method.
Source code:
http://www.agaverobotics.com/spinneret/source/
Source code:
I've been thinking about a different variation but I haven't implemented it yet. I was thinking that it would be useful to put this information in a standard text file saved on an SD card - something like address.txt. Instead of reading from EEPROM, it could just read from the card. A form like your configuration page could still be used to set the data.
Of course, this would require that you have a card on the board but they are so cheap these days that I don't see that being too much of a problem.
The major benefit I see to this approach is that you can edit that file on any PC, save it to the card, and then plug it into the Spinneret. You don't have to know a default IP or anything else to access the Spinneret the first time in order to change the configuration.
My plan is to use Roy's awesome DHCP code with the configuration code. That way network setting are remotely available when the Spinneret is assigned an IP. Just need ot add a little ping application to find the Spinneret or connect the Spinneret directly to a PC the first time or just do it with the Prop tool and spin . From there a user can assign an IP and disable DHCP or leave the settings as is. I think this is a better approach for ease of use for future Parallax Spinneret customers. Parallax can load the EEPROM during manufacturing. Plus a configuration interface provides a method to validate user input.
I'm not knocking your approach at all, do whatever is clever. I'm simply following a different path.
Looking forward to seeing your work. The more options available just make things easier for Spinneret users.
Regarding subnet masks, etc... I expect that 99.99999% of users can just be told that the subnet mask should be 255.255.255.0. So that's not too hard to specify.
I do have a question, though. Do you think the gateway IP is required in general or only for specific uses? I know a lot of things don't really care about it. This question has nothing to do with the approaches we are talking about, I'm just not sure what's really required.
If you use DHCP, then the user needs to identify the device. A lot of devices do this with a separate utility program that you run (which you mention in your post) - whether it's a custom program or a "ping" approach. Ideally, you will need to support that utility on multiple OSs (I guess if it's in Java, Python, etc. that can be handled pretty easily, but then people will need those installed). If you require it to be connected directly to the PC through USB, then people will need that additional hardware (prop plug or similar).
Of course, my approach requires people to have the ability to write to an SD card from their PC. I think having this stored as human readable text on the SD card is just more versatile than storing it on the EEPROM (although it requires more code in the Prop to parse it). The data can still come from DHCP - in that case maybe the file contents could look like this:
000820223939
DHCP
5000
Which would specify the MAC address and port. The rest could come from DHCP.
I guess we could all just add LCD displays to our devices to display the results of the DHCP.
Edit:
One other issue with using a utility to find the device occurs when you have multiple devices on the network. You need to identify which is which (the identification will be easiest by looking at the MAC address, I guess - assuming they have been configured with the correct one (matching the sticker)). I've been doing most of my testing with two Spinnerets on my network (mounted to a custom carrier board for now - I'm addicted to having things laser cut).
The Subnet mask is used to mask the address to see if it's outside the local network, and alter the packet accordingly.
But you can find those numbers on ANY computer on the local network as they al need to use the same values.
On windows, just open a command prompt(Start -> Run... "CMD.EXE")
Type this command:
IPCONFIG
And voila, you find all the numbers you need.
- I've noticed if the page is directed to a particular file, example;
Sometimes if http://IP_ADDRESS/file.ext is typed into the browser, it seems to crash the webpage.(-Your .jpg comes up fine when pointed to directly, until I type something else in that is - then I lock up the Spinneret)
-Is this due to the use, my misuse that is, of your temp.htm?
As I've mentioned in my thread, I'm trying to write to a text file, but I am having trouble hosting/accessing the text file from the SD card.
Thanks.
as dully noted from the thread here, I needed to include:
elseif strcomp(Request.FileExtension, string("js"))
StringSend(0, string("Content-Type: text/javascript")
I also needed to change:
StringSend(0, string("Content-Type: text/plain; charset=utf-8"))
Looks like things are moving forward now!
I do not really need the eeprom side
I try to make a quick html config page, last part of a project.
So push Ip web input settings to spin.
Thank-you
