Understanding Accelerometers
Hello everyone, this is probably a very novice question but i wanted to know what the ±3 g means when referring to an accelerometers sensitivity. Also, what are the limits on the accelerometers like the ones here at parallax, can they be used to record very quick acceleration for example. Any and all help would be much appreciated.
Thank you
Thank you
What do you mean by "can they be used to record very quick acceleration for example."?
Do you know of any that would be able to handle a maximum of 50g? I've a feeling this is way more than i need as this is the g force a missile (military) might encounter but i'm going with this because manned rockets are limited to 9g. i'll do some research and see if i can find a calculation for working out the expected g force or at least get a good estimate. Either way i'm going to need more than the 8g unit featured here at parallax.com. Again any help would be very much appreciated
Thank you
