Display Sth on computer screen using propeller demo board
NikosG
Hello everybody,
Since I've started with Propeller I have a basic question:
How can I display on my computer screen various results from my spin code e.g. the values of variables, text messages etc. (I know that I can use a 2X16 LCD display or a TV monitor) but I would like to use my computer screen.
In other words does exist a command like the "DEBUG" command of PBasic that I can use?
I use the propeller demo board and I know that it has a VGA port that I could use as an output, but I dont't have a second computer monitor.
In conclusion, If I need to see the various results on the same computer screen where I run the Propeller Tool, Is it posible?
Is any other additional software necessary?
Actually I thought the Propeller Tool also has such a terminal, not sure I have not used it for years.
This tutorial should help you get it working
http://www.gadgetgangster.com/tutorials/343
OBC
Thanks for the notice. I've probably seen PST mentioned before thinking it was just a typo on BST. I'll have to try it.
I've been using a TV/DVD player display which requires a bit of formatting to post variables and associated names. It is a bit more flexible as most all the 40 positions x 13 rows can be used; cost is a lot of lines to do that. Thanks again.
I've done the whole mini DVD as a debug screen as well. I've found it ALOT easier to take advantage of PST instead. I'll do an introduction to PropTerminal soon as well.
OBC
I used the method with Parallax serial terminal and it works!
I had already this tool on my PC but I hadn't realized its utility.
Propeller and spin language is really amazing!
The more I study propeller the more I like it!
Thank you for your help!
Take a look at post number 53 (on page 3). You can use your computer screen as a TV and directly show the output.
