Changing TV display colors
I am making great progress on my voicing counter display. This color thing is a real hangup. Although after it is operator selected, I'd hope to store the setting somehow to be retained on the next bootup. Any insight on that would be helpful as well.
I have yet to make much sense out of the colors for NTSC video. I have read many different threads, on and off these forums and still cannot get the concept for debugging this code. Some colors work as expected and some don't. The yellow or blue background does not get along. I get odd colors and gradients that seems to change luminance or some value in the color scheme.
What am I missing out on here?
How can this be resolved?
Is there a better method?
$0
$0
''* Voiced Counter & Display *
''* Copyright (c) 12/23/2010 *
''* See end of file for terms of use. *
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
_stack = ($2800 + 100) >> 2 'accomodate display memory and stack
x_tiles = 16
y_tiles = 10
paramcount = 14
bitmap_base = $5000
display_base = $5000
lines = 5
thickness = 2
bufferlen = 400
VAR
long mousex, mousey
long tv_status '0/1/2 = off/visible/invisible read-only
long tv_enable '0/? = off/on write-only
long tv_pins '%ppmmm = pins write-only
long tv_mode '%ccinp = chroma,interlace,ntsc/pal,swap write-only
long tv_screen 'pointer to screen (words) write-only
long tv_colors 'pointer to colors (longs) write-only
long tv_hc 'horizontal cells write-only
long tv_vc 'vertical cells write-only
long tv_hx 'horizontal cell expansion write-only
long tv_vx 'vertical cell expansion write-only
long tv_ho 'horizontal offset write-only
long tv_vo 'vertical offset write-only
long tv_broadcast 'broadcast frequency (Hz) write-only
long tv_auralcog 'aural fm cog write-only
word screen[x_tiles * y_tiles]
long colors[64]
long newcolor
long old1, old2, old3, old4
long D1, D2, D3, D4
long f_ext
byte f_name1
byte f_name2[2]
byte f_name_ext[6]
byte buff[bufferlen]
OBJ
'vp : "Conduit" 'Include this to set up ViewPort
tv : "tv"
gr : "graphics"
mouse : "mouse"
PUB start | i, dx, dy, numx
longmove(@tv_status, @tvparams, paramcount)
tv_screen := @screen
tv_colors := @colors
tv.start(@tv_status)
'init colors
numx := 1
colorswap(NUMX)
'repeat i from 0 to 63
'colors[i] := $00001010 * (i+4) & $F + $2B020C07 '2B_Foreground_0C_Background color
'1C=Blue 07=White
'8E=Yellow 02=Black
'07=White 02=Black
'02=Black 07=White
'init tile screen
repeat dx from 0 to tv_hc - 1
repeat dy from 0 to tv_vc - 1
screen[dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc + ((dy & $3F) << 10)
'start and setup graphics
gr.start
gr.setup(16, 10, 128, 72, bitmap_base) '(x_tiles, y_tiles, x_origin, y_origin, base_ptr)
'start mouse
mouse.start(24, 25)
D1 := D2 := D3 := D4 := "0"
longmove(@old1, @D1, 4)
'set font
gr.textmode(10,16,6,5) 'textmode(x_scale, y_scale, spacing, justification)
'my counter set at (10,16,6,5)
'D1 := D2 := D3 :=D4 :="9"
repeat
'clear only changed area
gr.colorwidth(0,8) 'text color and width 0,8
dx := 70
if old2<>D2
dx += 65
if old3<>D3
dx += 65
if old3<>D3
dx += 65
gr.box(135-dx,-72, dx, 142)
'draw digits
gr.colorwidth(2,8) 'text color and width 2, 8
gr.text(-95,0,@D4)
gr.text(-30,0,@D3)
gr.text(35,0,@D2)
gr.text(100,0,@D1)
longmove(@old1, @D1, 4) 'copy new digits to old
repeat until mouse.button(0)
if mouse.button(1)
repeat while mouse.button(1)
numx := numx+1
if numx > 7
numx := 1
colorswap(numx)
repeat while mouse.button(0)
Pri colorswap(NUMX) | i
case numx ' Foreground Background color
$1 :
newcolor := $2B1B0C07 '1B=Blue 07=White
$2 :
newcolor := $2B070C1B '07=White 1B=Blue
$3 :
newcolor := $2B8E0C1B '8E=Yellow 1B=Blue
$4 :
newcolor := $2B8E0C02 '8E=Yellow 02=Black
$5 :
newcolor := $2B020C8E '02=Black 8E=Yellow
$6 :
newcolor := $2B070C02 '07=White 02=Black
$7 :
newcolor := $2B020C07 '02=Black 07=White
colors[i] := $00001010 * (i+4) & $F + newcolor
return
DAT
tvparams long 0 'status
long 1 'enable
long %001_0101 'pins
long %0000 'mode
long 0 'screen
long 0 'colors
long x_tiles 'hc
long y_tiles 'vc
long 10 'hx
long 1 'vx
long 0 'ho
long 0 'vo
long 0 'broadcast
long 0 'auralcog
Take a good look through that commented version of graphics demo. The trouble you've got, is in the array that defines the colors. Try the methods in the commented program and you can trace through to see how the colors work easily. Each colors long specifies 4 colors, and those apply to all the tiles referencing that long in the colors array. You get sets of color, which you can assign to tiles. Once those are assigned, the color values 00, 01, 10, 11 then take on those colors within the tile.
repeat i from 0 to 63 colors[i] := $00001010 * (i+4) & $F + newcolor tv_colors := @colors
The original uses hex instead of binary. The background color was being thrashed by the 10? The following code modification has it working bug free!
repeat i from 0 to 63 colors[i] := $00001000 * (i+4) & $F + newcolor tv_colors := @colors
Now dare I ask, is there an explanation as to why the 10 was there in the first place? I don't see any obvious changes to the graphics demo version, although the array will reflect the change; the background color never changes in this particular demo.
What is more important here is this lesson forced me to learn greater details on my own. I cannot say it is all perfectly clear, but this is resolved.
Now on to storing the settings to the SD card or eeprom for booting it as set. Any pointers on this plan?
$0
In the file I linked, I've got that array in the dat section. Just put the sets of colors you want, somewhere in the Propeller memory, then point the tiles to them, by changing the lower order bits in the screen array. The methods in that file show you how this is done.
There is one array entry per tile. All the tiles can simply use one long for their color definition, if you want to do it that way. In that case, you would have a 4 color screen.
If you need 8 colors, then you define two colors array elements, and put 4 colors in one, 4 in the other, then assign those to the tiles as needed.
That concept can be expanded up to the 64 palettes possible, with the limitation of there being only 4 colors per tile.
As for the storing to the EEPROM or SD card, that's easy. Just put all your stuff in a DAT, and write the program to the EEPROM. That's what DAT area storage is good for, again demonstrated in the file I linked you to.
The math and loops in the original demo are fine for dynamically generating colors and such. Not necessary for most things.
I tried setting the array populating section posted above to 4 instead of 63. The screen did not like that. Changing it to the following still works. Which follows your idea that the colors in a DAT section would work as well, although here it seems to need at least an array of 10 to complete the screen. This may be due to the method that applies the tile data.
repeat i from 0 to 9 colors[i] := newcolor tv_colors := @colors
Maybe I was not clear on the SD/eeprom storage. My plan is for the program to retain the color setting. If the operator wants blue BG with yellow FG, I would rather they did not need to scroll back through each time it boots after a power down to reset their color preference again.
I expect this would take writing the current numx for "newcolor" dat to the SD or prom. Unless you are talkng about self modifying code. I have no experience there yet.
$0
That's a 4 color display, where you can choose to just use two of them.
If you incorporate this change:
repeat dx from 0 to tv_hc - 1 repeat dy from 0 to tv_vc - 1 screen[dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc '+ ((dy & $3F) << 10) 'I've commented out the original Parallax color scheme, which means all tiles are referencing 'Color Palette entry 0
To your program, all the screen tiles will be pointing to color array element 0.Then, just do colors[0] := your colors!
There is no syntax highlighting, so remove this "+ ((dy & $3F) << 10)" from your program to change how it sets up the screen array, and the tile color palette indexes.
That is what I meant by what was applying the tile data could be the problem....I guess that means some of this reading is sinking in.
I am grateful to have your assistance.
$0
DAT
colors long $07050302 (all greys)
long $07060504 (lighter greys)
... etc..
And you are set! Get rid of the colors array in the VAR section, and just make as many DAT entries as you need. Those will go to the EEPROM. You can get rid of that colors loop too. It's not needed in your case.
I can't help being satisfied with steps forward. Much appreciated Potatohead!
''*************************************** ''* Voiced Counter & Display * ''* * ''* * ''* Copyright (c) 12/23/2010 * ''* See end of file for terms of use. * ''*************************************** CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 _stack = ($2800 + 100) >> 2 'accomodate display memory and stack x_tiles = 16 y_tiles = 10 paramcount = 14 bitmap_base = $5000 display_base = $5000 lines = 5 thickness = 2 bufferlen = 400 VAR long mousex, mousey long tv_status '0/1/2 = off/visible/invisible read-only long tv_enable '0/? = off/on write-only long tv_pins '%ppmmm = pins write-only long tv_mode '%ccinp = chroma,interlace,ntsc/pal,swap write-only long tv_screen 'pointer to screen (words) write-only long tv_colors 'pointer to colors (longs) write-only long tv_hc 'horizontal cells write-only long tv_vc 'vertical cells write-only long tv_hx 'horizontal cell expansion write-only long tv_vx 'vertical cell expansion write-only long tv_ho 'horizontal offset write-only long tv_vo 'vertical offset write-only long tv_broadcast 'broadcast frequency (Hz) write-only long tv_auralcog 'aural fm cog write-only word screen[x_tiles * y_tiles] long old1, old2, old3, old4 long D1, D2, D3, D4 long f_ext byte f_name1 byte f_name2[2] byte f_name_ext[6] byte buff[bufferlen] OBJ 'vp : "Conduit" 'Include this to set up ViewPort ' tv : "tv" gr : "graphics" mouse : "mouse" PUB start | i, dx, dy, numx longmove(@tv_status, @tvparams, paramcount) tv_screen := @screen tv_colors := @colors tv.start(@tv_status) 'init colors numx := 0 colorswap(NUMX) 'init tile screen repeat dx from 0 to tv_hc - 1 repeat dy from 0 to tv_vc - 1 screen[dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc 'start and setup graphics gr.start gr.setup(16, 10, 128, 72, bitmap_base) '(x_tiles, y_tiles, x_origin, y_origin, base_ptr) 'start mouse mouse.start(24, 25) D1 := D2 := D3 := D4 := "0" longmove(@old1, @D1, 4) 'set font gr.textmode(10,16,6,5) 'textmode(x_scale, y_scale, spacing, justification) 'my counter set at (10,16,6,5) 'D1 := D2 := D3 :=D4 :="9" repeat 'clear only changed area gr.colorwidth(0,8) 'text color and width 0,8 dx := 70 if old2<>D2 dx += 65 if old3<>D3 dx += 65 if old3<>D3 dx += 65 gr.box(135-dx,-72, dx, 142) 'draw digits gr.colorwidth(2,8) 'text color and width 2, 8 gr.text(-95,0,@D4) gr.text(-30,0,@D3) gr.text(35,0,@D2) gr.text(100,0,@D1) longmove(@old1, @D1, 4) 'copy new digits to old repeat until mouse.button(0) if mouse.button(1) repeat while mouse.button(1) numx := numx+1 if numx > 7 numx := 0 colorswap(numx) repeat while mouse.button(0) Pri colorswap(NUMX) tv_colors := @colors[numx] return DAT tvparams long 0 'status long 1 'enable long %001_0101 'pins long %0000 'mode long 0 'screen long 0 'colors long x_tiles 'hc long y_tiles 'vc long 10 'hx long 1 'vx long 0 'ho long 0 'vo long 0 'broadcast long 0 'auralcog ' Foreground Background color colors long $00_1B_00_07 '1B=Blue 07=White long $00_07_00_1B '07=White 1B=Blue long $00_8E_00_1B '8E=Yellow 1B=Blue long $00_1B_00_8E '8E=Blue 1B=Yellow long $00_8E_00_02 '8E=Yellow 02=Black long $00_02_00_8E '02=Black 8E=Yellow long $00_07_00_02 '07=White 02=Black long $00_02_00_07 '02=Black 07=White
The reason for having the pri colorswap was for saving the setting to retain it somehow to restore it on boot. I will also be restoring the display count anyways as well.
$0
