Question about hooking up buttons....
jknightandkarr
I don't see that there would be an issue, but would it work to take a 3.3v DC supply & run it into a momentary pushbutton, then out from the button to a 150 ohm resistor & finally to I/O pins on the Propeller or into shiftregisters? Like I said being 3.3v I don't see an issue here. I'm working on a project & the layout is very cramped on my display side & there isn't room for resistors like the buttons circuit on the PPDB uses.
Joe
Joe
you can disregard the LED's.
Joe
