mapping system using 9 ping ultrasonic
i'm in a process on developing a mobile robot for my final project. i need to develop and use mapping system using lab view software. this mapping system use 9 ping ultrasonic sensor. anybody got info on this matter?
I believe the rotating disk would create echo's of it's own. A rotating horn might do the trick, but it would have to curved at the right angle to avoid resonsance frequencies.
Or something like this:
http://forums.parallax.com/showthread.php?123785-Reflector-to-enhance-PING)))-performance-available&highlight=Ping+reflector
Rotate a table with this mounted on it. Two units, back to back would give you 360 degree scan with a 180 degree servo.
Yeah, that works... Put 4 in 90 degree angles to each other and with a 90 degree rotation you get 360 degrees of maping. with tight timing, one could scan the room in a few seconds.
please i need help in project similar to your project
thx
