Is it possible to get a cash register sound from a piezo?
idbruce
Hi Everybody
I am just finishing up two CNC machines. One CNC will manufacture a product for which I have a patent pending and the other will package it. Approximately (hopefully) every three seconds, the first CNC machine should make the completed product, for which I intend to charge a quarter. When the machine is finished making the product, it pushes the product off the work area, down a slide, and into the packaging, making room for the next one. I have added a piezo siren to the machine for an audible indication of machine error, however, I would also like to use this siren if at all possible to show off just a little. When the product exits the work area, as it slides down into the packaging, I would like the piezo to play a cash register sound. Of course it would be a runtime option, because I know it would be annoying at forty thousand units a day
Is it possible?
Bruce
Is it possible?
Bruce
Congratulations on your products. I presume since you have asked here, you have a prop in the machines???
If it doesn't provide the audio quality you desire, you can consider filtering circuitry after you get enough power. I realize this all rather crude to an audiophile that wants a true sinewave at 0.1THD, but it is worth a try.
Of course, the other alternative is to feed a signal into a computer speaker pair that provides the amplification. Several circuits are available that attempt to clean up the square wave before it is amplified.
Piezo tweeters are not much better, I hate them (and I'm half deaf).
I did not think a piezo could handle it, but I thought I would check with the experts just to make sure. After reading your comments, I started searching for a suitable solution to my needs and desires. As previously mentioned, I need an audible indicator of machine error. The audible indicator does not have to be very loud and I believe the piezo will suit my needs. As for the cash register sound, I just want it to be faint enough to hear, but I want to be able to hear the sound crystal clear. First I looked at some old PC tweeters I had laying around, then I tore apart a telephone, and then it finally dawned on me that a headphone speaker would be the perfect solution.
I know that wav files can be saved in EEPROM, and I already have the cash register wav file. Now I just need to interface the headphone speaker to the propeller chip. Although it is not a complete solution yet, my partial solution is to have two sound outputs, one for machine error, and the other to play wave files.
Thanks for your comments.
Bruce
