IR sensors Same but Different?
In my stash of components I have two types of 3 wire IR sensors. Some are all black with a plastic casing and some have a silver metal covering that partially covers the sensor. The silver metal covered ones seem to be far less sensitive than the all black models. Is there a difference?
Steve
Steve
What are you trying to use them for? Is it for distance sensing or for a remote? Those modules come on different I/R detection frequencies so if one is on a different frequency then it may still work but only at a short range. 38Khz is very common but some are on 40Khz, 56Khz, etc
Robert
Steve
Per Robert, there are several center frequencies; you can copy part of the Scribbler or BoeBot program that runs a frequency sweep to test for reflected signals to see what the best frequency is.
