Photoresistor & Infrared-Headlight — Parallax Forums
botakbotak Posts: 13
edited 2010-12-14 07:34 in BASIC Stamp
Hi there! We try to put both "Photoresistor & Infrared-Headlight" in our BOE-bot robot. However only the Infrared-Headlight is working. So would it be possible if you guys can tell me if i've any connection error in my boe-bot or even in my coding. Thanks alot. (:
P.s. i've attached the coding in& the pictures of our boe-bot.
  • dandreaedandreae Posts: 1,375
    edited 2010-12-13 08:20
    Are you able to get just the photoresistors to work? I suggest setting up the circuit in chapter 6 of the "Robotics with the Boe-Bot" first and then add the IR circuit.
    Dave
  • botakbotak Posts: 13
    edited 2010-12-13 17:26
    Hi there,
    My photoresistors can't work. However my IR can work. Thats the problem )=
    The photoresistors themselves are normally robust. Did you verify that the I/O pins are working properly? Did you run the code on page 198 of the "Robotics with the Boe-Bot"? There is also a troubleshooting guide on page 199.
    Dave
