Navy rail gun video
Martin Hodge
What is your guess as to how the camera is able to follow the projectile at 0:29?
http://www.youtube.com/watch?v=6BfU-wMwL2U
Maybe something taking out of the Matrix filming?
Jim
Rich H
I think W9GFO is correct. If you watch the ground as the camera follows the projectile, you might get the sense the camera field of view is rotating around a vertical line not terribly far from the projectile path. Whereas a high def image with panning done in software wouldn't give that sense of pivoting since the camera would have to be located fairly far away.
The more I look the more it makes sense so a better question is what can this high tech cannon do that a conventional one cannot?
I always thought railguns would make great launchers of SAMs because no plume
back to where they launched. Once the missile reached a target altitude it would
ignite it's rocket and go into search mode for something to run into.
KK
I thought I caught a glimpse of a Propeller sticker. Could they be using a Prop to fire the IGBTs?
