Passive RFID Temperature sensing
Does anyone here have any experience in this? My application does not allow me to drill holes into the cavity with which I am wanting to monitor the temperature of so I am looking for a wireless and possibly a batteryless solution. The distance would be several inches or less. Prefer not to require a battery in the remote portion although something with very low low power that would run for many months to a year would be acceptable.
Thanks.
Don
Thanks.
Don
If you had a transparent window in the cavity, you could possibly use IR for communications using a battery. If there's an opaque, but non-conductive window, you could use low frequency electromagnetic signals like RFID uses with a small coil on both sides of the window. In this case, you could provide power as well. The simplest scheme would have a diode rectifying the received signal from the coil and storing power in a capacitor. The external controller would provide a signal for power for a period of time, then cut off the signal for a short time. The internal controller would listen for this and send either a short or a long pulse of energy at the same frequency to denote a bit value. This would be repeated enough times for all the bits and a checksum to be sent. A long period of power without a pause would reset the internal controller for the next sequence of bits.
As far as how often it might be read, probably not necessary to be much more than once a minute as the temperature would be slow to change. Maybe even longer but the point being it doesn't have to be very fast. The temperature range would be in the -15F to room temperature range.
I like your idea of RF energy being transmitted for a defined period of time to charge a capacitor then doing a quick read of the data. Do you know of any design examples using this?
I see from a Google search there are companies that already manufacture passive or semi-passive cards that are used in the food industry during transport and warehousing. Was thinking they may be more cost effective if the wheel doesn't need to be re-invented so to speak.
@ElectricAye- The outer cabinet is steel the same as any major appliance you may have in your home.
@Mike- Then I'll have to consider Plan B. The top of the cabinet utilizes glass sliding doors. And no I can't utilize anything optical as I cannot impede the access or looks of the sliding glass doors. I am thinking I should be able to use some sort of RF communication albeit won't be battery-less. X-Bee, Bluetooth, Cypress CyFi or something similar. It just needs to consume little power so as to preserve battery life.
If this cabinet is going to be -15F, just be sure your batteries can provide useful current at that temperature.
this sounds like a commercial display unit. It is definitely a low-tech approach but have you considered the drain plug most units that I'm familiar with how small plastic drain plug at the bottom of the unit for cleaning you can easily pass the wires for temp sensor through that whole just make sure you plug it back up with something or the cold will drain out the bottom.it deftly beats trying to drill a hole through the side and missing the refrigeration coils. And if it is that freezer unit batteries will be of little use inside.
Kevin
KI4SCC
