[resolved][puzzle] Carry on! — Parallax Forums
kuronekokuroneko Posts: 3,623
edited 2010-12-12 17:15 in Propeller 1
What am I after this time? Find a way of determining whether you ran out of cogs using as little resources as possible. This includes s/w as well as h/w.
    edited 2010-12-11 22:37
    if (cognew(@test, 0) < 0)
      sio.str(string("Oh dang! I'm out of cogs!"))
    DAT
    test    cogid    test
            cogstop  test
    I somehow have a feeling you were after more (i.e. less). :)
    edited 2010-12-11 23:20
    This time you're right. That's way too heavy. But at least that gives us something to work on.
    edited 2010-12-11 23:30
    You didn't specify whether the test was to be carried out in Spin or PASM. Which is it to be? I think it's also important to stipulate that if a cog is started because of the test, its effects must be nil, and it must be stopped. I think you also need to stipulate that the test be independent of anything that happens in the cogs that are running. IOW, they should not need to contribute to -- or be aware of -- the test.
    edited 2010-12-11 23:51
    You'd think I learnt something regarding how much info I must include to keep you happy ;) OK, for this exercise I might as well demand PASM.
    As for the other two criterias, admittedly I was afraid of stating the obvious. Not much good if you tear down the whole system by doing a simple test.
    • minimal to no impact on the running system, as stealthily as possible
    • no resource leaks (rogue cogs)
    Did I miss anything?
    Note, the test is done as part of your normal code so the PASM cog isn't started for the sake of the test.
    edited 2010-12-12 00:34
    One instruction (with undocumented carry behavior):
            cogid   $ nr,wc     'Set carry iff no more free cogs.
    Here's my test code:
    CON
       _clkmode       = xtal1 + pll16x
       _xinfreq       = 5_000_000
    PUB  Start
      repeat 5 'or 6
        cognew(@dummy, 0)
      cognew(@tester, 0)
      repeat
    DAT
                  org       0
    dummy         jmp #$
                  org       0
    tester        mov       dira,#1
                  cogid     $ nr,wc
            if_c  or        outa,#1
                  jmp       #$
    BTW, I'm guessing that, due to symmetry, clkset exhibits the same carry behavior, but I've not tested it.
    edited 2010-12-12 00:50
    Well done! That's what I had in mind. Either of rdxxxx/wrxxxx, cogid and clkset can be used. coginit and cogstop exhibit the same behaviour but have unwanted side effects.
    That said, the latest manual specifies carry cleared for most of them. Go figure.
    edited 2010-12-12 01:08
    Among that group of instructions, only cogid can be completely neutralized with the nr setting.
    The documenters must've felt it was not important enough to note -- or else they just didn't know about it. But yes, saying "0" is different than saying "-". In any event, this is useful enough to deserve being a separate instruction: cogtest. Now where's that macro assembler? :)
    edited 2010-12-12 01:25
    Fair enough. I was thinking more like that if you do a hub access anyway (as part of your code) you might as well force wc and look at it later.
    edited 2010-12-12 01:34
    Hmm, that's true, which effectively reduces the number of instructions required for the actual test to zero! :)
    edited 2010-12-12 01:44
    Out of curiosity, how did you arrive at your solution? I had mov[dis] and jmp[ret] figured out [post=864343]a while back[/post] and rdxxxx/wrxxxx were on my list for today.
    edited 2010-12-12 09:21
    The biggest clue, of course, was that it was you posing the question. That immediately suggested undocumented behavior. :) From there, I went to the instruction cheat sheet that I keep handy. With that, it's easy to spot instructions with similar bit patterns. The four hub instructions with S.bit2 == 0 (cogx's and clkset) stood out as a group, so it seemed natural to think they might all treat the carry flag the same if it wasn't committed to some other purpose -- and it's not. Among those, cogid is the only one that can be completely neutralized with nr, so it's the only one I tested.
    I'm surprised that rdxxxx and wrxxxx behave that way, too, since they're not in that group. But I would almost bet that if bit 2 of S in those instructions is a one, the carry flag will return lock status instead.
    Now, here's a follow-on puzzle: Is there an easy, non-destuctive way to tell if a particular cog is being used? (I haven't come up with an answer, BTW, and suspect it can't be done without cognewing the remaining cogs and eliminating their IDs from a pre-populated list.)
    edited 2010-12-12 16:56
    Touch
    edited 2010-12-12 17:09
    Another great find. I agree, shame we do not have macros to expand the compiler.
    Now, what do the unimplemented instructions MUL (000100), MULS, ENC, ONES do?
    Cluso99 wrote: »
    IIRC they clear the destination register and therefore set Z if you wish (on my demoboard that is). But that was only from a quick test.
