VGA and Prop Demo Board
Is it normal not to be able to down load a program to the Prop Demo Board while a VGA monitor is connected to that board?
To make it work, I have to disconnect the VGA monitor, down load the program, then reconnect the VGA.
VGA demo programs from parallax.
No other hardware connected to the Prop Demo Board.
Some cheap leads would short it out, but that would shutdown the DemoBoard perminantly (they do not do PCs much good either)
Downloads need the reset line to be cycled, I wonder if the VGA lead is somehow messing with that. Apart from the above I dont see how that could be.
(I only have homemade DemoBoard clones, with non-USB interfaces. I never connect the VGA pin 9)
I am guessing this is not normal.
For our OP, this might be tricky but it would be useful to compare earth on the VGA with earth on your demo board. But before you do that, what sort of power supply is running the demo board? There are some other unknowns here - eg if you were running off batteries the extra load of the vga pins could be enough to brown out the supply. The same could be true if running off a USB port.
