ViewPort Success: MagnetDrives AG uses Prop/ViewPort for 8 Megawatt resolver!
Hi,
ViewPort and the Propeller are being used in lots of cool projects- check this one out:
Background:
MagnetDrives AG is a company based in Zug, Switzerland that specializes in developing electrical motors and sensors for applications ranging from 60 mNm to 100 kNm. Recently, the company was tasked to develop and produce a resolver system for an 8 Megawatt synchronous motor. Put simply, they were asked to build a device which could accurately measure the angle of the motor's shaft. This measurement is important to control and optimize the motor's performance.
Problem:
MagnetDrives was asked to build an exotic measurement system in only 8 weeks.
Solution:
MagnetDrives chose proven off-the-shelf software and hardware to reduce development time of the resolver and qualification system. Pickup coils mounted on the perimeter of the 60cm diameter resolver detect the mechanical angle of the motor's shaft. Theses signals are fed to a custom PCB that features a Tamagawa chip whose output is read by a Parallax Propeller microcontroller. The Propeller runs code to process the resolver signal and also compares it with a reference Renishaw measurement system in order to qualify the resolver signals. ViewPort is used to display the microcontroller's results in real time using a familiar Digital Oscilloscope interface. ViewPort was also used to adjust calibration parameters on the fly and to export data to Matlab and Excel for later analysis.
Hanno
Background:
Problem:
Solution:
Hanno
Nice use of ViewPort and Propeller
Harley
Nice work.
Great work Hanno!
Jim
It's great to see industrial engineers taking advantage of Propeller and everything the community has built around it. I'm still in awe what cutting edge hobbyists have done with ViewPort+Propeller - in particular Mike's Turing machine and Chris' CNC controller and am now proud to help it succeed in the real world. I've posted several case studies and application notes on my site:
http://hannoware.com/viewport/applications.php
I've recently added several features to ViewPort- now at v4.5:
- professional quality C, spin, Basic editor with outlining, syntax highlighting, macros, regular expression search/replace
- integration of Michael Park's excellent HomeSpun Spin compiler, Parallax's Basic Stamp compiler, and continued support for Ross's superb Ansi-C compiler and Bob's C Debugger
- more professional look/feel and integration of editor and real-time graphing/data-logging
- support for multi-Propeller environments
Hanno
