BOE problem NOOB Help
Hello,
I inherited a new BOE BOT kit with a serial BOE. After I have it hooked up with a 9VDC wall wart, I measure VCC on the chip and see a nice 5VDC like I should. When I measure VCC on the proto headers I only see 2.2 VDC...Is this normal?
Rich H
I have a BS2 chip in a BOE, powered by a 9VDC wall wart. When I measure pin 21 on the BS2 (labeled VCC on the board) I see 5VDC as I should. When I measure the pin labeled Vdd on the header next to the proto typing area (or on the other header in the middle of the board) I get 2.2VDC. I do not see anything in the BOE schematic that would indicate a voltage drop.
By the way, when a run a test program to rotate a servo it runs,
Vdd is generated by the 5 volt regulator (LM340 - 5), Vcc is generated on board the BS2 from the Vin voltage, ( by it's own regulator). You may have a bad regulator. The reason you servo test ran is probably the jumper between the servo headers was set to Vin and not Vdd.
Jim
Rich H
