External Oscillator and Prop
How would one attach an external Oscillator to the propeller chip? I have the 5Mhz Oscillator from parallax and i can not get it to work.. nor any documentations with it... Thanks
Matt
Matt
_clkmode = XINPUT
No program runs, not even just setting outputs..
_xinfreq = 5_000_000
_clkmode = XTAL1 + PLL16X
The PLLnnX is used to specify the crystal frequency multiplier to produce the system clock. PLL16X will multiply the 5MHz to produce an 80MHz system clock which is commonly used.
