A Modbus-slave for a handwheel (Propeller) — Parallax Forums
Nick MuellerNick Mueller Posts: 815
edited 2010-11-23 05:46 in Robotics
Hi!
I have built this Modbus-interface (slave) to go to my mill (MAHO 700C). It will handle all the signals (switches, pushbuttons) in a remote-control (a hand wheel for jogging etc.).
Let's start with pictures:
The un-populated PCB (etched by PCB-pool, layout with EAGLE).
Soldering side of PCB. Yes, I made an error in the schematics. Flipped TXD and RXD.
TBC ...
if0.JPG 207.4K
if1.JPG 138.1K
  • Nick MuellerNick Mueller Posts: 815
    edited 2010-11-23 05:35
    Board populated.
    LCD showing some message.
    TBC...
    800 x 497 - 133K
    661 x 800 - 141K
    if3.JPG 133.1K
    if4.JPG 140.7K
    edited 2010-11-23 05:37
    Connections to the outside.
    Also needed an RS232 to RS485 converter. I'm already awaiting the first time I connect a DSub-9 the right way. :D
    TBC...
    800 x 577 - 124K
    800 x 448 - 134K
    if5.JPG 124.4K
    if6a.jpg 133.9K
    And here part of the control. Not showing the Modbus-interface.
    Technical data:
    * 24 TTL outputs. Enough to drive a LED
    * 24 TTL inputs (with pull downs).
    * In and out is done with shift registers. 3 * 74595 & 3 * 74166
    * opto-isolated RS232 (with an MAX232). Does up to 115200 Bd.
    * isolated two-wire (half duplex) RS485 with an ADM2483, also up to 115200 Bd.
    * bus (4-bit) to the LCD (a EA DIP204B).
    A few jumpers and LEDs for configuration and signaling.
    Code is written with ImageCraft's C-compiler.
    Response time (from last bit received 'till first bit sent) is 640 µs.
    The LCD is written to over Modbus by writing to 40 assigned registers (a Modbus-register has 16 bit). A complete screen update takes 2 ms at the control.
    The software on the Prop also has a configuration menue (by connecting a terminal to the RS232 and setting a jumper). Base-addresses for coils, inputs and LCD can be set. Also baudrate, ASCII- or RTU-mode, response-delay, end-of-message-time-out for RTU and other things I forgot. :-)
    Nick
    800 x 600 - 215K
    if7.JPG 215.3K
